Add More Models past 30
- clearprop88
24 Feb 2013 17:16 #6969
by clearprop88
Add More Models past 30 was created by clearprop88
How do I add more Models past the 30 default limit?
- Hexperience
24 Feb 2013 17:19 #6971
by Hexperience
Replied by Hexperience on topic Add More Models past 30
Did you try copying the default.ini to model31.ini model32,ini etc?
24 Feb 2013 17:19 #6972
Replied by PhracturedBlue on topic Add More Models past 30
just create more model##.ini files in the 'models' dir on your tx (copy the default.ini to model31.ini, etc)
You need to go in order, but shouldn't have any issue going to 99. 255 is the final limit but there may be some code preventing you from getting there right now.
- clearprop88
24 Feb 2013 19:28 #6979
by clearprop88
Replied by clearprop88 on topic Add More Models past 30
Thanks. That worked.
I also tried an experiment to see if I could create a block of model files.
I copied model21 through 30 into a temp folder, and renamed them model 31 through 40, and then copied them into the model folder. That worked fine.
It's a bit time comsuming.
Is there an easier way to do it?
- flyguy
24 Feb 2013 19:38 - 24 Feb 2013 21:39 #6980
by flyguy
Replied by flyguy on topic Add More Models past 30
as a quick workaround, try a batchscript like the attached one.
edit: i can't attach files, don't know why, here is the code (only useful in windows, just save it as .bat file, then move it to the models-directory and execute there):
@echo off
for /l %%x in (31, 1, 99) do (
copy default.ini model%%x.ini
Last edit: 24 Feb 2013 21:39 by flyguy.
- clearprop88
24 Feb 2013 20:29 - 24 Feb 2013 20:35 #6987
by clearprop88
Thanks flyguy.
That worked like a charm.
I had a model heli programmed into model1 when I first used the .bat file, so it copied that model heli into all the new files.
I went back, and copied the default file into model1, ran the .bat file, and it worked fine, so all the new files are default files.
I'm not up on my .bat files. I haven't used them in a long time.
If I replace "model1" with "default" in the .bat file would that work to copy the default file into all the new files?
Last edit: 24 Feb 2013 20:35 by clearprop88.
- Hexperience
24 Feb 2013 20:48 #6990
by Hexperience
Yep. Thats the better way to do it.
- flyguy
24 Feb 2013 21:37 - 24 Feb 2013 21:38 #6996
by flyguy
oh thats much better of course. i just hacked that together in a minute
... i will edit the code snippet for the others.
Last edit: 24 Feb 2013 21:38 by flyguy.
Time to create page: 0.700 seconds
