Devo 10 bind to E Sky EK2-0708 (Esky Big Lama)
  • Schiefy01
  • Schiefy01's Avatar Topic Author
  • Devo10 / Devo F7 / Devo F7DS
13 Feb 2015 20:34 - 13 Feb 2015 20:41 #28639 by Schiefy01
is there the possibility to bind the Devo 10 to the Esky EK2-0708 2.4GHZ 4in1 Receiver?
Or to Upgrade the Devo to this Module and Protocoll?
The Board inside the Esky 2.4G tx is: module TX1P08B
3 Wires black, red, white
I use the Devo also for other Heli´s and Planes, but they are equipped with devo RX and 2801pro RX...
Thanks in advance for assitance :-)
Sven
Last edit: 13 Feb 2015 20:41 by Schiefy01.
13 Feb 2015 20:39 #28640 by SeByDocKy
Replied by SeByDocKy on topic Devo 10 bind to E Sky EK2-0708 (Esky Big Lama)
Did you try to install the last Nightly build, there two ESKY protocols... maybe one of them can work
  • Schiefy01
13 Feb 2015 21:45 - 13 Feb 2015 21:51 #28642 by Schiefy01
Replied by Schiefy01 on topic Devo 10 bind to E Sky EK2-0708 (Esky Big Lama)
Thanks,
now i modified to the last Nightly build and find now 2 Esky Protocols :-)
*ESky150
*Esky
... but i cant bind, there is a Star in front of (*ESky150 / *Esky)
Do i need to add a new Module to the Devo?
Which one i´ll had to use?
or how to install the one i have?
In the Supported Models Sheet isn´t a Module to the ESky referenced :-(
many thanks in advance
Sven
Last edit: 13 Feb 2015 21:51 by Schiefy01.
  • Schiefy01
14 Feb 2015 19:43 - 14 Feb 2015 19:44 #28674 by Schiefy01
Nobody an Idea ??
Last edit: 14 Feb 2015 19:44 by Schiefy01.
14 Feb 2015 19:49 - 14 Feb 2015 19:51 #28675 by Indigo
The Star in front of the protocol name indicates that the corresponding hardware ( a required transmitter module ) was not found.
Last edit: 14 Feb 2015 19:51 by Indigo.
  • Schiefy01
14 Feb 2015 20:14 #28678 by Schiefy01
thx.
i tried to understand the Post, but cant find Esky Module inside.
Did somebody kno the requiered Module an how to Install this one?
BR
Sven
14 Feb 2015 22:15 - 14 Feb 2015 22:20 #28682 by aMax
...nRF24L01+ module (with PA & LNA).
Protocol Esky150 & Esky.
Last edit: 14 Feb 2015 22:20 by aMax.
  • Schiefy01
17 Feb 2015 22:38 #28761 by Schiefy01
can somebody confirm this works?
www.amazon.de/dp/B00SEEQ1NE/ref=pe_386171_38075861_TE_item
... sorry for my bad knowledge on this issues :-(
17 Feb 2015 23:07 #28764 by victzh
No, the module you linked to is most likely CC2500 which is one of the standards used by RC, but not compatible with nRF24L01+. Module sellers most often advertise their modules in such way to catch searches, but the first name is most likely the true one.
  • Schiefy01
17 Feb 2015 23:31 - 17 Feb 2015 23:34 #28766 by Schiefy01
thats hardcore for somebody without expirience in this modules...
Can't find the right ones.
The ones in eBay looks not the Same as in the Module Installation sheet here in Page.
Could you please Post the Link where i can order one.
EBay, amazon or equal.
Best with the smal antenna conection in Board, to put a wire inside the tx for this Module.
Thx
Last edit: 17 Feb 2015 23:34 by Schiefy01.
  • Schiefy01
18 Feb 2015 16:49 #28830 by Schiefy01
18 Feb 2015 17:38 #28838 by hexfet
That will work but range will be limited because it does not have a Power Amplifier. If that's a concern look for a model that has the PA (second chip) like this one .
Time to create page: 0.397 seconds
