Multimodule install questions
- Jasenk
05 Jan 2016 04:41 #41388
by Jasenk
-Jasen
Multimodule install questions was created by Jasenk
I have a Devo 10 and plan on adding an MM board with a nrf24l01 chip for now and the other two later. I've read many many post but I still have some questions.
I'm confused about the stock Devo cyrf6936 , some places I see to remove it and possibly put it on the MM board, other places I see it stay in the stock location. Is this optional or something? Can someone please explain?
Also I bought the ATtiny84A chip and I saw something about it not being the 24 chip and changing t24 to t84. What does that mean? Any setup I need to be aware of for the different chips? I ordered the 1.3 version card and intend to program it via the TX. Any special dfu file for the 84 version?
Sorry if this has been answered already.
-Jasen
- RedSleds
05 Jan 2016 08:26 #41394
by RedSleds
Replied by RedSleds on topic Multimodule install questions
The MM board is made for a couple different Tx's, some of which do not have a CYRF transceiver. So then a CYRF can be added to the MM board. Since the DEVO line of Tx's already have a CYRF in them, you don't put one on the MM.
If I recall correctly, when using the DEVO 10 to flash the ATtiny, you don't need to worry about that edit from 24 to 84. I think that only applies when using a USBasp to do the flash of the ATtiny.
Here's my experience on the MM build, not a real how-to or tutorial, but has some tips and ideas.
>>> www.rcgroups.com/forums/showthread.php?t=2441459 <<<
- Jasenk
05 Jan 2016 11:46 #41400
by Jasenk
-Jasen
Replied by Jasenk on topic Multimodule install questions
Thanks for the quick reply. I understand now. That makes sense.
-Jasen
Time to create page: 0.049 seconds
