Newbie needs help to setup switch on devo 7e
12 Nov 2016 10:59 #55866 by myjoejoe
Good day guys,
can someone here please help me to configure switches on my devo 7e or will be kind to shear his or her config file . I would like to use one for arming and the other for angle / horizon mode in betaflight.
I've been able to bind the tx with the receiver without any hassle. But I can't get the tx to arm the quad and I don't have any knowledge on how to use the mixer to map or set the appropriate channels on the Devo 7e with deviation install. Not even which switch is this or that.
Am using this spacer f3 board;
m.banggood.com/Eachine-Micro-32bits-F3-B...Frame-p-1075953.html
And
m.banggood.com/REDCON-2_4G-6CH-CM651-DSM...tible-p-1042946.html
Any help would be greatly appreciated.
Thank you.
08 Dec 2016 08:03 #56653 by micro heli club
Replied by micro heli club on topic Newbie needs help to setup switch on devo 7e
Hello!!
I am in the same trouble.
AUX 1 (HOLD), AUX 2 (FMOD) switch can not be assigned.
(combination)
DEVO7E+S-FHSS(SF800 SB) +F3 EVO Brushed
Please let me know if there are any improvement measures.
08 Dec 2016 08:12 #56654 by myjoejoe
Replied by myjoejoe on topic Newbie needs help to setup switch on devo 7e
Hello I have been able to fix it by following a tutorials on YouTube and here are the link to it;
I hope that it help's you to fix it.
08 Dec 2016 08:23 #56655 by micro heli club
Thankyou!!!
DSM2⇒OK
S-FHSS⇒NG
I am in trouble with combination with S - FHSS(S-BUS) receiver.
08 Dec 2016 08:27 - 08 Dec 2016 08:35 #56656 by myjoejoe
Well with that one I don't know much about it but I do think you should watch the videos they have a lot of information in it, which can guide you to fix it.
And on the D7e too you need to setup the mixer too to assign the aux 1 for hold and aux 2 for fmod to get it to work.
The first video he is using Devo 7e which he shows how to set it up
And the second video he is also using Devo 10 to show how to setup channels for the mode section to arm, rate and so on
Last edit: 08 Dec 2016 08:35 by myjoejoe.
Time to create page: 0.599 seconds
