Walker Super CP for 7E
09 Aug 2013 07:40 #12862 by hazzanz
Replied by hazzanz on topic Walker Super CP for 7E
This is what I am using - cut off Tom Z's beginner's template. I have added a little negative pitch for flying in the wind. The picture is off here as well but I can't recall who posted it... :unsure:
09 Aug 2013 10:01 #12867 by hazzanz
Well that sucks....
07 Dec 2013 15:08 #16370 by SilbernerSurfer
Replied by SilbernerSurfer on topic Walker Super CP for 7E
hazzanz wrote: This is what I am using - cut off Tom Z's beginner's template. I have added a little negative pitch for flying in the wind. The picture is off here as well but I can't recall who posted it... :unsure:
I am totaly new in programming a Tx for a helicopter too.
For what is channel 7 in this config file?
And if there is a little bit negative pitch in this file in whitch position should be my throttle stick at binding?
07 Dec 2013 16:04 #16373 by FDR
Replied by FDR on topic Walker Super CP for 7E
Ch7 used to be the gyro channel for the DEVOs...
07 Dec 2013 17:44 #16381 by WheresWaldo
Replied by WheresWaldo on topic Walker Super CP for 7E
SilbernerSurfer wrote: ...
The amount of pitch programmed in doesn't make any difference, just make sure the throttle stick is at the lowest position.
07 Dec 2013 18:14 #16383 by SilbernerSurfer
FDR wrote: Ch7 used to be the gyro channel for the DEVOs...
Thanks a lot FDR and Waldo.
Can i use the silver buttons on the Devo 7e for the gyro channel?
07 Dec 2013 18:42 #16385 by FDR
I think no, but you can use the trims of the throttle stick instead...
08 Dec 2013 09:38 - 08 Dec 2013 09:39 #16400 by SilbernerSurfer
How can i get the model file and the bmp in my nightly build?
I have tried it, but after copy and paste and switch on the tx it shows "bad/missing protocol".
Last edit: 08 Dec 2013 09:39 by SilbernerSurfer.
  • rbe2012
  • rbe2012's Avatar
08 Dec 2013 10:54 #16402 by rbe2012
Replied by rbe2012 on topic Walker Super CP for 7E
This happens if you did not copy the "protocol" folder from the devo7 file system on your tx. Has nothing to do with model configs or icons.
10 Dec 2013 18:45 #16498 by SilbernerSurfer
The protocol file is added to file system. The devo 7e works perfect until i add the new model file from above.
10 Dec 2013 20:22 #16506 by SilbernerSurfer
What is the excactly way to add this model file to the devo 7e?
  • rbe2012
  • rbe2012's Avatar
11 Dec 2013 06:28 #16517 by rbe2012
Just put it in the "models" folder. Did you rename it? It must have a name like modelXX.ini where XX is a unique number between 1 and 99 and they have to be used without any gaps in numbering (search stops if a number is unused; overwrite a model for which you haven't made a config or choose the next free number). Otherwise it will not be found.
But I don't believe that a wrong named file will harm.
...I tested the file in the emulator. Files with wrong names are not recognized, nothing more happened.
11 Dec 2013 17:02 #16530 by SilbernerSurfer
Yes, i tried it this way i think. I will try once again. Thanks for the help rbe. :-)
24 Dec 2013 13:03 #16970 by SilbernerSurfer
It works now, thx a lot.
Time to create page: 0.689 seconds
