Old V120d02 and wk 2603 transmitter
- Fredic
16 Aug 2013 22:24 #13007
by Fredic
Old V120d02 and wk 2603 transmitter was created by Fredic
hello everybody
I'm new to this forum .... and I need your help!
I have a V120D02 (old model) with Wk-2603 old old transmitter... so I bought a DEVO8S and I installed Deviation V 3.0.0 (nigthly builds) and almost everything works ... except models V120D02S downloaded here. Is there any problem with the channel numbers compatibility between those tx?
I do not understand! Can you help me? thank you
17 Aug 2013 09:30 #13015
Replied by rbe2012 on topic Old V120d02 and wk 2603 transmitter
As far as I know the V120d02 and the new S have different receivers so there might be a difference in the settings. If you walk through the deviation manual and compare the settings with those published by Walkera for the WK2603 you should see if there is a difference.
There is also a good howto which describes the way to get a FBL heli configured: http://www.deviationtx.com/forum/how-to/1226-how-to-set-up-fbl-helis-on-custom-firmware
17 Aug 2013 09:37 #13016
They are for DEVO protocol, so you have to change it to WK2601 or better to WK2801...
Replied by FDR on topic Old V120d02 and wk 2603 transmitter
Fredic wrote: ...and almost everything works ... except models V120D02S downloaded here.
- Fredic
17 Aug 2013 13:02 #13017
by Fredic
Replied by Fredic on topic Old V120d02 and wk 2603 transmitter
thank you for your answers
I tried to change the protocols according to different models but the binding problem arises sometimes. the led of the receiver will turn off at the end of the bindind process and sometimes cyclic not work???
What can be the difference between the receivers? rx2610V (old one) and rx2636H-D
I will read "fbl heli" and continue my test ...
- Fredic
07 Nov 2013 17:17 - 07 Nov 2013 17:19 #15422
by Fredic
Hi everyone
I come back with the same problem and many questions! (i read V2.0 / V3.0 manuals and How to set up FBL helis...but my english is not so good!!
I still have not succeeded to make my old V120D02 (with rx2610V for TX WK-2603) works with my DEVO8S under Deviation 3.0. (all works great with my V200D03!)
I tried all Walkera protocols, the binding seems to work with WK2801protocol, but only the throttle and rudder work. I first got here a model for V120D02S but it did not works.
Then I created a model for FB heli. So I programmed the model the same as my WK-2603 i.e Swashplate 120, ELE channel to Cyclic 1 ans AIL channel to Cyclic2 ...
I do not know which channel to put PITCH and Gyro?
Can you help me? I'm going crazy!.
Last edit: 07 Nov 2013 17:19 by Fredic.
07 Nov 2013 17:44 #15423
I would give an other try to the downloaded V120D02S model file: change the protocol to WK2801, and clear the fixed id. It sould bind after that.
You will also probably have to move the gyro channel from Ch7 to Ch5...
Pitch is Ch6, the gyro on the older Walkera models is probably Ch5, but it is on Ch7 on the DEVOs with more then 6 channels.
- Tierod
07 Nov 2013 20:35 #15426
by Tierod
Replied by Tierod on topic Old V120d02 and wk 2603 transmitter
And if FDR's suggestion still doesn't work try lowering channels in w2801 protocol to 6.
Had same problem and at the time was trying so many things I can't remember exactly what it was that fixed it.
Rod
Rod
- Adriaan
08 Nov 2013 17:15 #15449
by Adriaan
Replied by Adriaan on topic Old V120d02 and wk 2603 transmitter
I also had some trouble with my old v120d02 and Deviation.
Heres my ini (devo10), perhaps this can help you
- Fredic
09 Nov 2013 09:05 - 09 Nov 2013 10:37 #15466
by Fredic
hi guys
Thank you for your help
I try everything and I tell you....
Last edit: 09 Nov 2013 10:37 by Fredic.
- Fredic
10 Nov 2013 08:31 #15484
by Fredic
This is great! it works!
Programming the 2801 Protocol with 6 channels ... and also reversing the PITCH channel!
Thanks thanks thanks!
I will not be crazy ... this time
Time to create page: 1.110 seconds
Model Configs
- Old V120d02 and wk 2603 transmitter
