Walkera V200D03 - Standard Settings
13 Jan 2014 03:58 - 30 Apr 2014 15:18 #18458 by Tom Z
  • Throttle hold on the RUDD D/R switch.
  • 7 Point Throttle and Pitch Curves.
  • TX Power=100mW
  • Channels=7
  • Protocol=DEVO
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 24 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
    Model 24-2 has Zero Degree Pitch when throttle hold is on.
    If you want control of the swash in TH to help you land in a crash don’t use this model use Model 24 instead.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: -2* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
62% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 75% gyro gain.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Last edit: 30 Apr 2014 15:18 by Tom Z.
Time to create page: 0.106 seconds
