Blade mCPX V1/V2/BL - 3D Settings
26 Jan 2014 16:37 - 15 Feb 2014 23:31 #19167 by Tom Z
Blade mCPX V1/V2/BL - 3D Settings was created by Tom Z
This model is for the Blade mCPX V1/V2 and mCPX BL.
  • Throttle hold on the RUDD D/R switch.
  • 7 Point Throttle and Pitch Curves.
  • TX Power=100mW
  • Channels=7
  • Protocol=DSMX
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 34 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
    Model 34-2 has Zero Degree Pitch when throttle hold is on.
    If you want control of the swash in TH to help you land in a crash don’t use this model use Model 34 instead.
Throttle Curve - These are the values I used then converted them to the deviation values and 7 point curves.
Normal: 0% 40% 60% 80% 100%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP +30%
0- AILE D/R = 100% EXP +30%
RUDD D/R = 100% EXP -6%
Switch Position
1- ELEV D/R = 125% EXP LIN
1- AILE D/R = 125% EXP LIN
Last edit: 15 Feb 2014 23:31 by Tom Z.
26 Jan 2014 19:39 - 26 Jan 2014 19:56 #19197 by Tom Z
Replied by Tom Z on topic Blade mCPX V1/V2 /BL - 3D Settings
I forgot to add my custom GUI. I just added it and re-uploaded the models.
If you downloaded the file before I posted this you should download the model again as that model will use the default GUI on your transmitter and not my custom GUI which works on all the transmitters, has all the switch icons assigned to them, and has a custom layout for your home screen.
Last edit: 26 Jan 2014 19:56 by Tom Z.
01 Feb 2014 21:35 #19631 by dwhacks
Replied by dwhacks on topic Blade mCPX V1/V2 /BL - 3D Settings
I just got an MCPX from a buddy, so Im new to this whole thing. Could you explain what the switches do? I cant figure out what the GEAR switch does. I think I have all the other figured out though.
01 Feb 2014 21:52 #19638 by Tom Z
The switch functions vary depending on what you program them to.
For this model I didn't assign anything to the Gear switch or MIX switch.
02 Feb 2014 00:46 #19660 by dwhacks
Thanks. I thought I was missing something because it showed up on the home screen. I get it now and my heli is flyin great! thanks!
28 Mar 2014 19:25 #21914 by stéphane
Replied by stéphane on topic Blade mCPX V1/V2 /BL - 3D Settings
Have you config for MCX ( not MCPX) ?
29 Mar 2014 15:49 #21935 by Tom Z
Replied by Tom Z on topic Blade mCPX V1/V2/BL - 3D Settings
Here is a list of all the models I have on this site. deviationtx.com/forum/model-configs/2555...pter-and-quad-models
I don't have a model for the MCX. I just saw your other post that you found a model for your MCX.
29 Mar 2014 19:32 #21938 by stéphane
Replied by stéphane on topic Blade mCPX V1/V2/BL - 3D Settings
Yes ,
It's realy a good job !!!
It's work well , deviationtx and people work is very fantastic.
No regret to have chosen walkera RC.
30 Mar 2014 02:22 #21948 by Hondawasaki
Replied by Hondawasaki on topic Blade mCPX V1/V2/BL - 3D Settings
Tom Z wrote: Here is a list of all the models I have on this site. deviationtx.com/forum/model-configs/2555...pter-and-quad-models
i think I posted one if not ...i do have a MCX2 model that will work fine. even made a model icon :)
30 Mar 2014 07:14 #21953 by stéphane
Yes ,
MCX2 config work very fin for MCX , thanks !
It's nice.
20 Apr 2014 16:34 #22604 by Hondawasaki
your welcome ...and feel free to edit as you like
08 May 2014 12:42 #23004 by dobosatti
Replied by dobosatti on topic Blade mCPX V1/V2/BL - 3D Settings
Bl MCPX helicopter gyro sensitivity devo 12s radio that I set?
08 May 2014 15:44 #23015 by Tom Z
I am not sure what you are asking.
If your asking how to set the gyro gain there is no need to.
Gyro gain on the mCPX is preset in the Flybarless 3n1 Control Unit.
This is why I don' have any gyro gain set or listed in my description.
I hear there is a way to adjust the gyro gain if you wanted to but I can't confirm this.
deviationtx.com/forum/model-configs/2169-mcpx-bl#13751
08 May 2014 19:59 #23028 by hexfet
Replied by hexfet on topic Blade mCPX V1/V2/BL - 3D Settings
I can confirm the tail gyro gain is adjustable on the BL on channel 5. The adjustment range isn't large, but is noticeable. I use a value of 40 and it does reduce the tail wag on mine, at least for just flying around. Not doing 3D yet.
Note from Horizon Hobby
08 May 2014 20:46 - 08 May 2014 21:11 #23032 by Tom Z
Thanks hexfet.
That means if someone wanted to adjust the gyro gain with my model they would need to assign a mixer and value to channel 5.
Channel 5 is set to Mixer = None
This is due to the gyro on the mCPX is preset in the Flybarless 3n1 Control Unit.
Here is one way to add an adjustable gyro gain. Scale is the gyro gain amount.
This is using your value of 40 converted to the deviation value.
Last edit: 08 May 2014 21:11 by Tom Z.
09 May 2014 07:38 #23055 by dobosatti
Thank you for your response.
I'll try.
Switch may be more value as well?
For example, three-position switch mix?
Mix0 = +20
Mix1 = 0
Mix2 = -20
09 May 2014 13:44 - 09 May 2014 13:48 #23066 by Tom Z
Your welcome.
A three-position switch mix would work well.
I am assuming hexfet used a Spektrum value of 40. If it was a Deviation value of 40 then use 40 instead of -20.
Mix0 = +40
Mix1 = 0
Mix2 = -40
Try different values and test fly it to find out what works best for you.
Here is my Tutorial on Converting deVention values to deviation values.
deviationtx.com/forum/how-to/2620-conver...-to-deviation-values
Last edit: 09 May 2014 13:48 by Tom Z.
09 May 2014 19:41 - 09 May 2014 19:42 #23080 by hexfet
My 40 is a deviation value. From my understanding of Horizon Hobby's note this is higher gain than default. The default gain is the same as a 0 channel value (middle of the range). On deviation values less than zero will give less gain than the factory default.
Last edit: 09 May 2014 19:42 by hexfet.
28 May 2016 01:38 #49414 by 3D Ambitions
Replied by 3D Ambitions on topic Blade mCPX V1/V2/BL - 3D Settings
I recently acquired an mcpx BL and have been using Tom Z's 3d file with my 8s and it works fantastic. Setup my gyro on gear channel as recommended and setp a value of 40 as stated and my wag is gone tail still holds great on hard pitch changes. I was getting some tail bounce when going neutral on the collective coming out of an intense stunt. Now the tail holds stead. Thanks , just wanted to document this and express my gratitude.
Time to create page: 1.698 seconds
