Nine Eagles Solo Pro 125 - Beginner Settings
04 Feb 2014 23:28 - 15 Feb 2014 23:39 #19841 by Tom Z
Nine Eagles Solo Pro 125 (125A)
  • No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast.
  • Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
    If you fly outside in wind use ST-1 or ST-2 which have full pitch curves which can pull the heli down in wind.
  • Throttle Hold on the RUDD D/R switch.
    Zero Degree Pitch when throttle hold is on.
    This will help minimize damage in a crash as the swash and blades will be at mid stick zero degrees pitch. This will also help prevent a boom strike.
  • 7 Point Throttle and Pitch Curves
  • Low dual rates and positive expo to tame the heli down
  • Throttle hold on the RUDD D/R switch
  • TX Power=100mW
  • Channels=6
  • Protocol=J6Pro
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 45 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gyro Gain - These are the values I used then converted them to the deviation values.
Gear Switch
Pos 0: 38%
Pos 1: 75%
Throttle Curve
Normal: Custom Curve
ST-1: 100% Flat Across
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Hover at about half throttle.
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
Last edit: 15 Feb 2014 23:39 by Tom Z.
Time to create page: 0.400 seconds
