DEVO 8S DEVIATION ,DSM2 NEED SETTINGS FOR 450FBL
27 Feb 2014 07:43 - 27 Feb 2014 07:44 #20917 by thomasprevere
hi,first time with deviation and dsm2,can you post some settings to start with my tarot 450 and dsm2 protocol or any file to download in advanced mode?
I will use robird g31 and satellite that works with 1 servo 90 ccpm mixing.
Last edit: 27 Feb 2014 07:44 by thomasprevere.
27 Feb 2014 17:59 - 27 Feb 2014 18:01 #20930 by HappyHarry
Replied by HappyHarry on topic DEVO 8S DEVIATION ,DSM2 NEED SETTINGS FOR 450FBL
if your using the advanced GUI then the best place to start would be to load the 6ch heli template and then go from there, go into the model settings and set the protocol to dsm2, then go into the swash settings and change it to 1 servo. that will get you in the ballpark and it will just be a case of sorting servo reverse (if needed), end points, throw etc, whilst doing the fbl setup. if you get stuck on anything specific post back. I have a microbeast setup for dsm2 sat usage that would most likely get you started but it's setup for the standard GUI not the advanced.
Last edit: 27 Feb 2014 18:01 by HappyHarry.
28 Feb 2014 07:50 #20950 by thomasprevere
Replied by thomasprevere on topic DEVO 8S DEVIATION ,DSM2 NEED SETTINGS FOR 450FBL
Standar GUI is more easy to start,but i would like to learn the advanced GUI.
I start with this in advanced gui dsm2,helicopter,1 servo and reverse, then my servo tail didn't respond when i move the rudder stick ,somehow i find it ,but i can't figure out how you set the throttle curves,throttle hold or fix the UI1 IU2 at this advanced GUI...
Maybe i must try the standar GUI...
03 Mar 2014 19:50 #21152 by thomasprevere
File Attachment:
File Name: model1.ini
File Size:4 KB
:whistle:
03 Mar 2014 20:14 - 03 Mar 2014 20:15 #21155 by RandMental
Replied by RandMental on topic DEVO 8S DEVIATION ,DSM2 NEED SETTINGS FOR 450FBL
HappyHarry wrote: .... set the protocol to dsm2, then go into the swash settings and change it to 1 servo.
For those reading this in isolation - this is not necessarily the case, it depends on which 3axis gyro controller you use: 3GX (3 Servos) Beastx (1 Servo/Normal), etc.
Last edit: 03 Mar 2014 20:15 by RandMental.
04 Mar 2014 13:30 - 04 Mar 2014 13:32 #21175 by HappyHarry
thomasprevere wrote: I will use robird g31 and satellite that works with 1 servo 90 ccpm mixing.
as you can see my post was in direct response to thomas asking for directions for his robird g31 that requires 1 servo swash setting, i can't see why people would read my instructions and think otherwise? and the only way to read it in isolation is in your chopped quote?
Last edit: 04 Mar 2014 13:32 by HappyHarry.
07 Mar 2014 09:47 #21336 by thomasprevere
I finally setup it ,after a lot of reading and help from a friend,i don't understand how to set properly the travel adjust for throttle cause my motor max out at 70 % :unsure:
07 Mar 2014 10:39 - 07 Mar 2014 10:41 #21338 by RandMental
This may be a feature of your Gyro Controller, most of them eg 3GX and Beastx has a setup mode when you tell it (calibrate) the range of your throttle signal. It must be done on most controllers, especially those that include a governor function.
Did you do a stick calibration on the Devo and are you sure you don't have dual rates enabled?
Lastly move the Devo Throttle Scale from +100 to +125, that might just take yo to full power.
Last edit: 07 Mar 2014 10:41 by RandMental.
07 Mar 2014 23:51 - 09 Mar 2014 20:31 #21367 by thomasprevere
I don't have problem with stick calibration or something else,my only problem is that my hp08 motor max out at 70% throttle,so i can't set the governor value% to know what headspeed i am running,because if the motor max out at 70% then i must set the governor to 45-50% to work properly but then i don't know the right headspeed that i am running in blheli program :unsure:
Last edit: 09 Mar 2014 20:31 by thomasprevere.
08 Mar 2014 11:25 - 08 Mar 2014 11:36 #21377 by HappyHarry
sounds like you need to calibrate the esc's throttle end points, wait an hp08 in a 450? if you are now talking about using blheli's pwm to ppm conversion on a micro heli then that is the issue, I came across the same thing in my fbl80 bl swap, as already mentioned maxing the throttle end points will help a bit with that, but I still couldn't get a full range throttle stick even then
Last edit: 08 Mar 2014 11:36 by HappyHarry.
09 Mar 2014 00:26 - 09 Mar 2014 20:22 #21384 by thomasprevere
Hpo8 on 450 .. :lol:
No,but the settings for my v120d02s and my 450 are almost the same, coz i use robird on v120 10a esc with blheli and i have calibrate the esc with this video
that works with my previous tx futaba 7c
Now i calibrate it but it max out at 65-70% and i know that this problems with throttle calibration are most when the signal is pwm ,pwm you can't calibrate it,only ppm,so i don't understand why the motor max out at 70 and not to 100% throttle :dry:
Last edit: 09 Mar 2014 20:22 by thomasprevere.
10 Mar 2014 18:21 #21428 by thomasprevere
Ok,i found how to fix the throttle curve, my motor max out at 65% throttle so i reduce the scale + to 65 and now i have linear throttle from -100 to +100 ;)
Time to create page: 0.219 seconds
