V922 (FBL100) Is this normal?
11 May 2014 19:03 - 11 May 2014 19:03 #23147 by Solmer
V922 (FBL100) Is this normal? was created by Solmer
Hi, I downloaded a FBL100 model file for my V922 and I've adjust it to suit my needs, i mean basic fly , no 3D, so I've a pitch curve with NO negative pitch and a max of 75% angle. The throttle curve goes from 0 to 100... I can hover without problems in a small area (at least for me) but when i land the heli I noticed that the trims has changed so switching off and on my Devo 7e I got a warning telling me that the throttle is over 0... Is this normal?
I've attached my model file....
Thanks in advance.
File Attachment:
File Name: model15.ini
File Size:4 KB
Last edit: 11 May 2014 19:03 by Solmer.
02 Jul 2014 07:52 #24347 by matrixFLYER
Replied by matrixFLYER on topic V922 (FBL100) Is this normal?
This problem is related to the upgrade of the firmware deViation. I got the same problem. I hade to fix every old model. Check channel assignment. Even to me the helicopter was working but the channel assignment was wrong and it was working only for a case!
Time to create page: 0.116 seconds
