Walkera LadyBug V2
- Torch
01 Jun 2014 00:05 #23798
by Torch
Walkera LadyBug V2 was created by Torch
Deviation v4 with Devo 7E LadyBird V2 only binds and stays in Flip mode (Green lights). How do I setup Flight Mode switch to enable and turn off Flip mode?
- Bullfrog
01 Jun 2014 05:16 #23804
by Bullfrog
Replied by Bullfrog on topic Walkera LadyBug V2
3D Mode is switched by Ch7, assign a switch to Ch7 with values -34 / 66.
Example:
[channel7]
template=complex
[mixer]
src=Ch7
dest=Ch7
scalar=-34
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE2
scalar=66
curvetype=fixed
Example:
[channel7]
template=complex
[mixer]
src=Ch7
dest=Ch7
scalar=-34
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE2
scalar=66
curvetype=fixed
- Torch
01 Jun 2014 21:57 #23833
by Torch
Replied by Torch on topic Walkera LadyBug V2
Thanks add this to model.ini using notepad ++ or tx config file? How do assign channel using standard or advance setup?
01 Jun 2014 22:17 #23834
Replied by PhracturedBlue on topic Walkera LadyBug V2
The easiest way is to add it with notepad++.
But if you want to do it in the Tx, you would go to the Ch7 mixer, setthe template to complex, set the number of mixers to 3, then enter the values as Bullfrog showed (the 1st [mixer] is mixer, the next [mixer] is mixer2 and the 3rd [mixer] is mixer 3).
- Torch
01 Jun 2014 23:49 #23835
by Torch
Thank you do i add this to model.ini? I rather use notepad ++ method.
- Torch
04 Jun 2014 18:45 #23908
by Torch
Resolved using Tom's Devo7E model.
Time to create page: 0.095 seconds
Model Configs
- Walkera LadyBug V2
