V202, JD 385 throttle not giving enough lift
- ErikZ
28 Sep 2014 20:03 #25856
by ErikZ
V202, JD 385 throttle not giving enough lift was created by ErikZ
I'm running a modded devo 7e together with a JD 385 quadcopter and the 4.0.1 firmware.
The problem is that even when i max out the throttle I do not get enough lift power to rise from the ground.
This worked with the original remote before I harvested the BK2423 transmitter from it.
Any ideas on how to troubleshoot this?
Thanks,
Erik
Thanks,
Erik
- Wene001
01 Oct 2014 20:55 #25903
by Wene001
Replied by Wene001 on topic V202, JD 385 throttle not giving enough lift
Do you have the Sticks calibrated?
Is the Channel output going from -100 to +100?
- ErikZ
03 Oct 2014 07:52 #25933
by ErikZ
Replied by ErikZ on topic V202, JD 385 throttle not giving enough lift
Problem solved.
I had mounted the propellers incorrectly.
Time to create page: 0.423 seconds
Model Configs
- V202, JD 385 throttle not giving enough lift
