Need help with Setting JJRC H8C 4-speed button
06 Apr 2015 04:27 #30824 by 30secs
Guys, I have the JJRC H8C. It has a 4 speed button: 25%, 50%, 75%, 100%
I'm trying to set the throttle trim to go up/down between these. Is that possible?
I've figured out the following
first 4 channels -- normal flying channels
channel 5: lights on off (mapped to hold)
channel 6: flip mode (mapped to fmode)
channel 7: i believe this one is the agility level (25%, 50%, 75%, 100%)
in the original tx it's a single button. I'm trying to map it to the throttle (LV) button. Can you help me? I've included my INI below.
name=JJRC H8C/X6
mixermode=Advanced
[radio]
protocol=V202
num_channels=8
tx_power=150mW
[channel1]
reverse=1
template=simple
[mixer]
src=AIL
dest=Ch1
[channel2]
template=simple
[mixer]
src=ELE
dest=Ch2
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
reverse=1
template=simple
[mixer]
src=RUD
dest=Ch4
; lights on/off
[channel5]
template=simple
[mixer]
src=HOLD1
dest=Ch5
; flip on/off
[channel6]
template=simple
[mixer]
src=FMODE1
dest=Ch6
[channel7]
template=simple
[mixer]
src=Virt1
dest=Ch7
[channel8]
template=simple
[mixer]
src=Virt2
dest=Ch8
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Virt1
pos=TRIMLV+
step=193
value=-100,0,0
[trim6]
src=Virt2
pos=TRIMLV-
step=193
value=100,0,0
[timer2]
type=countdown
time=10
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,39,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Model setup
quickpage2=Channel monitor
Time to create page: 0.996 seconds
