6 fight modes using 2w & 3w zwitches on Devo 10
- avatr11
06 Aug 2015 13:48 #36606
by avatr11
6 fight modes using 2w & 3w zwitches on Devo 10 was created by avatr11
I am trying to use the 3w FMODE switch and the AILE 2w switch to get a tt"otal of 6 flight modes but have not had any sucess setting up the mixes. I can get 3 modes OK with the FMODE switch but cant seem to figure out how to use the 2w switch. What I would like is a numeric value for each of the 3 positions of the FMODE switch when AILE is in one position and three different numbers for the FMODE positions when the AILE is switched. Any help would be appreciated!
06 Aug 2015 14:28 #36607
Replied by mwm on topic 6 fight modes using 2w & 3w zwitches on Devo 10
You're just thinking about it backwards in order to do it with deviation. If you attack it as wanting the AIL DR switch to set two different values for each FMODE position, it's obvious, and you can do something like this (untested):
[mixer]
src=AIL DR0
dest=Ch5
switch=FMOD0
curvetype=min/max
points=0
[mixer]
src=AIL DR0
dest=Ch5
switch=FMOD1
curvetype=min/max
scale=66
points=0
[mixer]
src=AIL DR0
dest=Ch5
switch=FMOD2
curvetype=min/max
scale=33
points=0
WIth FMOD0, AIL DR sets ±100, with FMOD1 it sets ±66 and with FMOD2 it sets ±33, but that's just because those are easy values. You could also set scale to 20 in all 3, and then set offset to -60, 0 and 60 to get values of FMOD0 AIL DR0 -80, AIL DR1 -40, FMOD1 AILDR0 -20, AIL DR 1 20, FMOD2 AIL DR 040 and AIL DR1 80.
[mixer]
src=AIL DR0
dest=Ch5
switch=FMOD0
curvetype=min/max
points=0
[mixer]
src=AIL DR0
dest=Ch5
switch=FMOD1
curvetype=min/max
scale=66
points=0
[mixer]
src=AIL DR0
dest=Ch5
switch=FMOD2
curvetype=min/max
scale=33
points=0
- TomPeer
06 Aug 2015 14:53 #36611
by TomPeer
Replied by TomPeer on topic 6 fight modes using 2w & 3w zwitches on Devo 10
You could do something like this with a virtual channel.
You have to set the value's to your own wishes. this is just an example.
- avatr11
07 Aug 2015 02:13 #36631
by avatr11
Replied by avatr11 on topic 6 fight modes using 2w & 3w zwitches on Devo 10
Thanks for the help! Have it working now. I had tried that combination but did not use the min/max values. Your explanation with the offsets works although the outputs are backwards.
Time to create page: 0.312 seconds
Model Configs
- 6 fight modes using 2w & 3w zwitches on Devo 10
