Eachine QX95 with DSM receiver and Devo10
- ZeroFPV
11 Apr 2017 14:51 #61378
by ZeroFPV
Replied by ZeroFPV on topic Eachine QX95 with DSM receiver and Devo10
Different protocols mean different channel orders and different channel mids and end points. You should check in the Cleanflight configurator if your yaw channel is really at 1500. If you are off from the proper channel mid this will cause a constant drift on that channel. If your channel mid is off in the Cleanflight GUI you can adjust it in the channel settings of your Devo. Subtrim is what you are looking for.
- Wanderer777
12 Apr 2017 16:15 #61405
by Wanderer777
Replied by Wanderer777 on topic Eachine QX95 with DSM receiver and Devo10
Yes the channels were a little bit off and I used subtrim to correct them. They are now all centered to 1500.
However, I can't get the TX to use the full channel range from 1000 to 2000. Minimum range is 1039 .No matter what I try (scale, offset etc.), I doesn't go beyond this limit and it also never reaches the max range of 2000.
Should I leave this as it is, as long as all the channels are centered now?
- Deal57
12 Apr 2017 16:24 #61406
by Deal57
Replied by Deal57 on topic Eachine QX95 with DSM receiver and Devo10
This is a common problem. At the end of
this page are some options for the rxrange command.
13 Apr 2017 01:20 #61412
Replied by mwm on topic Eachine QX95 with DSM receiver and Devo10
Just FIY, you can also fix the channel ordering problem in deviation. There's a page for reordering channels you can get to from the mixer page.
Time to create page: 0.595 seconds
Model Configs
- Eachine QX95 with DSM receiver and Devo10
