Connect runner 250 PRO to multiwii
21 Apr 2017 13:34 #61658 by joaonunofz
Connect runner 250 PRO to multiwii was created by joaonunofz
i have a walkera runner 250 PRO and i I can not connect it to the pc and multiwii , can anyone help me?
11 May 2017 20:28 - 11 May 2017 20:30 #62239 by claim777
Replied by claim777 on topic Connect runner 250 PRO to multiwii
1) Install to your PC driver for Walkera runner from installation file "Walkera FlyConfig"
2) Turn ON your DEVO
3) Turn ON your Runner
4) place micro-USB cable to main controller Runner 250 and connect this cable to your PC USB port.
5) if you need MultiWiiConf - start it, select work com port (if com port will works - it change color to green)
6) push "Start" and enjoy it !
if your com port not have green color after select it - you no have installed driver on PC
7) if you need MultiWiiWinGUI - start it, select your work com port, speed 115200, and push Connect.
8) enjoy it :)
Last edit: 11 May 2017 20:30 by claim777.
11 May 2017 20:36 #62240 by joaonunofz
Replied by joaonunofz on topic Connect runner 250 PRO to multiwii
But ... is it through the flyconfig that the drivers are installed?
But is not flyconfig just to install the firmware on the drone?
11 May 2017 20:56 #62241 by claim777
you write questions - "I can not connect it to the pc and multiwii , can anyone help me?"
for start multiwii - you need install drivers (these drivers includes in installation flyconfig file)for connect with your Runner 250.
flyconfig need only for install the firmware on the drone.
for change setting and any experiment - you need MultiWii
11 May 2017 21:01 #62242 by joaonunofz
My question is that if your computer needs the drone drivers, you did not need to connect the drone to flyconfig, but just look for them and install them directly on your computer ...
Well the drone already has the firmware installed ... if I do this will not do any harm? Like it getting disorganized or something of the genre ... is that I'm afraid to screw something into the drone's brain and I can not fix it
11 May 2017 21:12 #62243 by claim777
No need start flyconfig. Only install drivers to your PC (from installation flyconfig).
after installation drivers - start MultiWii and use it for see and changing setting your drone
11 May 2017 22:37 #62244 by joaonunofz
Flyconfig asks for a bin file that I do not have ... where is ??????
Watch the video I made ... drive.google.com/drive/folders/0B6Q3z_sG...YYjY3Y0k?usp=sharing
12 May 2017 00:45 #62246 by joaonunofz
i tryed to install drivers (from installation flyconfig)...but flycongig asks for a BIN file that I do not have ... where is THE BIN FILE????
IF NOT A FILE BIN, what file to use ???
I went here www.walkera.com/index.php/Download/info/id/43.html and downloaded all the software , But I can not find the file for the walkera flyconfig...can you help me please?
12 May 2017 06:50 - 12 May 2017 07:03 #62252 by claim777
download driver from here - www.walkera.com/downloads/aibao/USB%20Up...%20Tool%20Driver.rar
and install it to your PC
OR -
I download flyconfig here - walkera-fans.de/download/tools/walkera_f...Installation-1.0.zip
this installation file contains folder with needed drivers, about which I wrote earlier.
Last edit: 12 May 2017 07:03 by claim777.
12 May 2017 10:54 #62254 by joaonunofz
thanks I'll try
23 May 2017 21:58 #62515 by joaonunofz
I can not connect my runner to the walkera flycongig , i used the file : WALKERA_FCS_RUNNER-250-PRO_DFU_V1.0.5.dfu
01 Feb 2025 16:12 #78636 by Sport
Replied by Sport on topic Connect runner 250 PRO to multiwii
claim777 wrote: 1) Install to your PC driver for Walkera runner from installation file "Walkera FlyConfig"
8) enjoy it :)
Time to create page: 0.572 seconds
