Hubsan H107l
  • RCFUN0102@gmail.com
  • RCFUN0102@gmail.com's Avatar Topic Author
22 Jan 2018 23:05 #67054 by RCFUN0102@gmail.com
Hubsan H107l was created by RCFUN0102@gmail.com
Hello all.. when using the Hubsan H107..... it does not allow me to turn on the LEDs.... please help
24 Jan 2018 00:51 #67092 by Gerry
Replied by Gerry on topic Hubsan H107l
Lights on/off work on channel 5 for hubsan
FFS (Forever Fixing Stuff)
24 Jan 2018 01:12 #67093 by RCFUN0102@gmail.com
Replied by RCFUN0102@gmail.com on topic Hubsan H107l
Thanks so much for getting back to me...there is hope ;) ch5 is that’s the a,b,c or d? And I flipped all of them and did not see any difference...thanks again..RCFun’s Diversions on you tube
24 Jan 2018 01:16 - 24 Jan 2018 01:18 #67094 by Gerry
Here is hubsan ini for devo 7e, lights are always on with this one.
All rates are high and mode switch turns on or off flip mode.
Last edit: 24 Jan 2018 01:18 by Gerry.
24 Jan 2018 01:27 #67095 by RCFUN0102@gmail.com
I don’t know what to do with that...but please leave it..I need to do some more research..I have the jumper t8sg thx btw...thanks
24 Jan 2018 01:43 #67096 by Gerry
In mixer go to ch5.
for light permanently on set curve type = fixed and scalar to 100.
for lights turn and off with switch set curve type = min/max and set source to switch of your choice.
25 Jan 2018 20:00 #67157 by RCFUN0102@gmail.com
Well I got the lights to work on channel 5..thanks!!! Now flip mode and high speed??? Hmmmmmm any assistance is appricieated....
25 Jan 2018 21:08 #67158 by Gerry
flip mode is on ch6, curve type = min/max and set source to switch of your choice.
There is no channel specifically to change rates.
If your Ail/Ele/Rud channels are set as simple with 1-1 curve type and scalar at 100, that is as good as it gets.
25 Jan 2018 22:01 #67159 by RCFUN0102@gmail.com
Ok I think it is set up.. but actually I could never flip the h107L with the controller it came with... so no biggy .. the lights work though and thats really important fore night flights.... Also I put the scale to 110 to see if it gave it a little more punch.. I thought it did but could be my wishful thinking... anyhow lastly I also have a H107c Cam Plus.. and it flies fine with controller. but how can I start and stop video and take a picture.... is that something that simply cant be done.. as always thanks for the help.. your awesome!
25 Jan 2018 22:43 #67162 by Gerry
Flipping the Hubsan requires rocking the cyclic stick from full one direction to the full opposite direction, and throttle down a bit as it goes upside down and throttle back up as it returns right side up (or it will drop heaps and probably hit the ground).
Sorry I don't have a camera version so have no idea about the controls for that. Searching the forums should find the answers though.
Time to create page: 0.594 seconds
