Wizard V220 w/ BetaFlight throttle .ini question
13 Feb 2018 03:07 #67480 by Brett_N
HI Folks - Couldn't fit it in the subject, but I'm using the attached .ini on a Jumper T8SG with FrskyX reciever.
I've got betaflight setup, and I can arm and disarm, and test motors through the interface, but when I use my TX, things get wonky.
Basically - throttle stick (left vertical, Mode 2) at idle is dead center. Down stick spins correct direction but with a controlled throttle curve. Center stick up is full throttle only and the quad just tumbles over.
Is there a way in the .ini to modify it for a single "normal" type bottom to top type throttle? Or do I need to figure this out in BetaFlight?
14 Feb 2018 05:21 #67506 by Deal57
Check your control order. This ini is set to the DSMX standard Throttle, Aileron, Elevator, Rudder (TAER), but most Frsky controllers use AETR... but also the ini is using AFHDS-2, so it's the wrong protocol and you're sending the throttle output on the Aileron channel. First double check that this is the ini you're actually using.
Time to create page: 0.129 seconds
