Blade Nano QX
- Skysurfer
21 Mar 2015 22:54 #30015
by Skysurfer
Blade Nano QX was created by Skysurfer
I have a Nano Qx any configs?
- Skysurfer
06 Apr 2015 22:15 #30854
by Skysurfer
Replied by Skysurfer on topic Blade Nano QX
Can you share it please?
07 Apr 2015 01:53 #30859
Replied by mwm on topic Blade Nano QX
Here's mine for the Devo6S.
Flight mode switches on the EXT button.
You'll need to fix the switches on most other Tx's: dual rates is on the D/R switch, sticky throttle hold on the GEAR switch, and timer reset on the MIX switch. Fix them in the main page toggle configs as well.
Icon is from the icons section of the forums.
- Skysurfer
07 Apr 2015 05:10 #30865
by Skysurfer
mwm much thanks but I am using a DEVO 10.
- gordonzo
15 May 2015 22:35 #32633
by gordonzo
Different fly for different guy.
Replied by gordonzo on topic Blade Nano QX
@Skysurfer - did you get your Devo 10 config file?
All my ini files can be downloaded here:
lonagord.wix.com/bigglittleo-1#!devo-10---deviation-40/c24ax
g
g
16 May 2015 03:03 #32638
The deviation files can be shared between different transmitter models. You just need to check/fix the switches.
Time to create page: 0.522 seconds
Model Configs
Model Requests
- Blade Nano QX
