Parkzone Sport Cub - Need Config for Devo 10
01 Apr 2015 03:30 #30600 by nwoodschris
Just ordered this: www.horizonhobby.com/products/PKZ6880
Parkzone Sport Cub. Anyone have a file that will work with a Devo 10? Thank you. It has a DSMX receiver. Note this is not the "S" model with SAFE.
02 Apr 2015 01:19 #30661 by nwoodschris
Replied by nwoodschris on topic Parkzone Sport Cub - First Try at Config
Okay I have tried my first dual rate setup for this plane on my Devo 10. I am just learning so I would be grateful if anyone would be willing to look at it for me and comment, make suggestions and help me predict if it will work with the Parkzone Sport Cub. Thank you.
File Attachment:
File Name: SportCubBasic.ini
File Size:4 KB
03 Apr 2015 03:59 #30729 by mwm
Change the fixed ID to something random, and then rebind your aircraft. Two models with the same id will bind to either aircraft, which is usually not a good idea.
You're only using 4 channels but have six configured. Not a big deal, but I tend to reduce those if I happen to catch it.
03 Apr 2015 12:26 #30744 by nwoodschris
Replied by nwoodschris on topic Parkzone Sport Cub - Need Config for Devo 10
Okay I fixed the channels and added a "sticky throttle hold". How do I get the display to turn the "TH" icon on and off when the throttle is active/inactive (not just the switch) and so it shows the throttle output (%)?
Time to create page: 1.101 seconds
