Eachine H8C Mini?
01 Dec 2015 20:00 #40533 by bmw111
Eachine H8C Mini? was created by bmw111
Anyone have a model.ini for this model? I believe it uses Bayang protocol.
01 Dec 2015 23:36 #40542 by goebish
Replied by goebish on topic Eachine H8C Mini?
It uses the Bayang protocol but snapshot / recording are not implemented.
I should have tx captures soon, I'll add them to the protocol.
02 Dec 2015 01:51 #40544 by bmw111
Replied by bmw111 on topic Eachine H8C Mini?
Thanks. So how does one go about capturing the info you coders need? I'm not a coder but if it's something I could do for the new multirotors I buy, I'll help out.
02 Dec 2015 03:28 #40550 by hexfet
Replied by hexfet on topic Eachine H8C Mini?
goebish wrote: have a look at this thread:
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
feel free to ask if you need more help :).
20 Dec 2015 13:36 - 22 Dec 2015 10:17 #41054 by goebish
I made a test firmware:
- in Model screen dialog, click "Bayang", set "Test" to "On" then check for each values of P2 and P3 if snapshot or video recording is enabled then report back, thanks :)
Devo7e
Devo10
Last edit: 22 Dec 2015 10:17 by goebish.
22 Dec 2015 10:11 #41087 by goebish
Check this firmware with H8C mini:
Devo7e
Devo10
Channel 7: snapshot
Channel 8: video recording
Please report back :)
02 Jan 2016 14:37 #41309 by IKKI
Replied by IKKI on topic Eachine H8C Mini?
Yeah, thanks! I have jjrc h98 and use Bayangtoys protocol. Now I'm at IKEA with my lady, but after I can try!
03 Feb 2016 14:54 - 03 Feb 2016 14:59 #42544 by FrankV
Replied by FrankV on topic Eachine H8C Mini?
Hi all,
maybe interested: I installed the v4.01-97b55c0 on my Devo 10 and the Eachine H8 mini flies very well. Much better then the original transmitter.
As for the setup file, I saw different ini files.
If interested, I attached my ini file with some improvements compared to the others:
Mix 0 = normal rate
Mix 1 = roll/pitch expert, yaw normal
Mix 2 = roll/pitch/yaw, expert mode
FMD 0 = Normal flight mode
FMD 1 = Headless mode (first calibrate both sticks by putting them in the lower right position)
FMD 2 = RTH (Return to home, but don't forget to calibrate its position before flight: both sticks in lower left position)
Left trim and/or Right Trim (+ or – button) = Flip mode. Pressing the button (upwards or downwards) will result in a single flip. While using another switch the flip command stays on and caused me a several unexpected flips. Therefor the momentary (puls) command.
Rudder = safety switch: Throttle disabled.
If rudder enabled, the rates of roll/bank (ail/elev) are set to "expert mode" in order to be able to calibrate the H8 mini before each flight (sticks lower left and lower right position). If you set lower rates in MIX 0, calibration is not possible.
Trims enabled. The trim buttons of the opposite stick are used. E.g. the left_h stick trims the horizontal right stick (aileron).
The used switches are shown on the main page.
PPM IN option enabled (used for a trainee), just check your channel assignments
Hope this helpes!
(the icon I used found it from someone else on this forum)
Last edit: 03 Feb 2016 14:59 by FrankV.
Time to create page: 1.116 seconds
