Corona
- victzh
25 Oct 2013 18:32 #14975
by victzh
Replied by victzh on topic Corona
Protocol decoding effort depends on several factors. I decoded several, and track development effort on many more, and in my opinion the hardest part is frequency hopping algorithm.
Packet structure is pretty straightforward to decode - record the SPI traffic while pulling the TX controls. Sometimes there are peculiarities - SLT packet, e.g. contains mixed bit width - 10-bit for mail channels, and 8-bit for 2 extra channels.
Frequency hopping can be of very varying difficulty - from table defined to pseudo-random number generator. The latter is the hardest as was encountered in DSMX case. It required efforts of a cryptographer to decode.
As Frsky algorithm is decoded (though it uses simplified pseudo-random algorithm) you can be lucky in it.
Also in my experience it makes more sense to connect your logic analyzer to receiver, not transmitter, because in this way you can see what channel the receiver anticipates the next packet and you can experiment with new TX ids not having dozens of actual transmitters.
- Birdman
- victzh
- Birdman
- Birdman
27 Oct 2013 13:05 #15039
by Birdman
Not the most popular but i believe a lot of people use it and those that do usually have a few rx. I have at least 6.
I don't have a problem putting in the time, my biggest concern is do i have the skill? I think no, but with a little guidance and a lot of homework i may be able to do it.
I will get a bus pirate, could take 10 days to get here, and see how far i get.
Bm
Replied by Birdman on topic Corona
victzh wrote: I don't know how popular is this Corona? If it is, may be it is reasonable. But yes, it is a lot of work.
Bm
- Birdman
- Birdman
- Birdman
- victzh
04 Nov 2013 15:01 #15331
by victzh
What is this? If you want us to analyze this, say so. If so, can you at least pass it through SPI filter so that the messages would be more sensible, and provide annotations about the circumstances: what did you trace - receiver or transmitter - is it from the very beginning or in the middle of the session, was it bound or not etc. etc.
- Birdman
- Birdman
04 Nov 2013 15:42 - 04 Nov 2013 15:43 #15333
by Birdman
This is what i have captured and analyzed with bus pirate, first attempt.
Will have to find out what spi filter is.
Trace is of rx after binding to tx, no sticks moving.
Bm
victzh wrote: What is this? If you want us to analyze this, say so. If so, can you at least pass it through SPI filter so that the messages would be more sensible, and provide annotations about the circumstances: what did you trace - receiver or transmitter - is it from the very beginning or in the middle of the session, was it bound or not etc. etc.
Bm
Last edit: 04 Nov 2013 15:43 by Birdman.
- Birdman
- Birdman
- victzh
04 Nov 2013 17:54 #15344
by victzh
To trace a protocol you need a bit larger span. And something is not working in your connection with the device. Do you have graphical view, something like this:
dumb.ro/lafront/screenshot1.png
and can you verify that what you see resembles SPI - CSN goes down and up, SCK is active while CSN is down, the SPI decoder decodes it.
- Birdman
04 Nov 2013 23:06 - 04 Nov 2013 23:34 #15350
by Birdman
This trace is of rx powering up.
BP -> CC2500
MOSI -> pin20 SI
CLK -> pin1 SCLK
MISO -> pin2 SO
CS -> pin7 CSn
Are the grey lines in analysis errors?
They should be green white green white....?
BP -> CC2500
MOSI -> pin20 SI
CLK -> pin1 SCLK
MISO -> pin2 SO
CS -> pin7 CSn
Last edit: 04 Nov 2013 23:34 by Birdman.
- Birdman
- victzh
05 Nov 2013 17:31 #15361
by victzh
The forum software reduces the pictures so I can not see clearly. The former one is too zoomed out to tell anything.
You should consult CC2500 datasheet, www.ti.com/lit/ds/swrs040c/swrs040c.pdf to see if what you're looking at resembles actual CC2500 commands. Section 10 describes the interface and Section 32 - registers.
Can this software (I worked with OLS long time ago) save SPI decoded trace in some text format?
Time to create page: 2.070 seconds
- Corona
