DEVO7E+S-FHSS ENDPOINT
05 Sep 2016 10:35 #53497 by micro heli club
DEVO7E+S-FHSS ENDPOINT was created by micro heli club
Can not set the end point from 1000 to 2000 in a DEVO7E + S-FHSS + F3 EVO Brush Flight Control Board + Cleanflight (CF).
Fixed in 1110-1930.
Not reflected be set to MAX-250 ~ + 250.
05 Sep 2016 10:41 #53499 by aMax
Replied by aMax on topic DEVO7E+S-FHSS ENDPOINT
... and if you use subtrim to midpoint 1500 it will be even more less on top.
05 Sep 2016 10:52 #53502 by micro heli club
Replied by micro heli club on topic DEVO7E+S-FHSS ENDPOINT
Thank you!!!
Again from 1110 to 1930 it does not change.
It is always 1110 to 1930.
Setting of Cleanflght (CF) is 1,000 to 2,000.
05 Sep 2016 10:55 #53503 by FDR
Replied by FDR on topic DEVO7E+S-FHSS ENDPOINT
Have you calibrated your sticks?
05 Sep 2016 11:30 #53506 by micro heli club
yes~~~
If DSM2 receiver will operate normally.
I think that due to the S-FHSS of protocol.
Original 100 size (Gravy100)
05 Sep 2016 12:01 #53507 by Ryou
05 Sep 2016 12:21 #53508 by micro heli club
Oh my god ~ ~ ~http://www.deviationtx.com/media/kunena/emoticons/pinch.png
Change to DSM2.
Thank you!!!
07 Sep 2016 20:45 #53601 by victzh
Replied by victzh on topic DEVO7E+S-FHSS ENDPOINT
This can be fixed - I indeed did not test it on the original Futaba receiver - I don't have one. We have the protocol value calculated as
(u16) (496 - (ch * 410 / CHAN_MAX_VALUE))
which limits it by 86-906, while I suspect the actual range is 0-1023. So the range in internal units - 820 - matches the range in ms, also 820.
08 Sep 2016 12:54 - 08 Sep 2016 12:57 #53633 by Ryou
Replied by Ryou on topic DEVO7E+S-FHSS ENDPOINT
I'm sorry will not be improved.
More than 100% of the scale will not be reflected.
100% scale is the same as the FUTABA 1.52ms + -0.41ms.
FUTABA You can configure up to 140%.
The 140% setting is 1.52ms + -0.57ms.
Last edit: 08 Sep 2016 12:57 by Ryou.
08 Sep 2016 13:10 #53634 by micro heli club
Thank you :)
DSM2 is operating normally on the satellite receiver.
08 Sep 2016 16:02 #53641 by victzh
@Ryou, @micro heli club, what receivers do you use?
09 Sep 2016 02:55 #53664 by Ryou
victzh wrote: @Ryou, @micro heli club, what receivers do you use?
I'm sure in OrangeRx SF700S receiver.
It compares the FUTABA T8J transmitter in the same receiver.
PWM width has been observed by the digital oscilloscope.
09 Sep 2016 02:56 #53665 by micro heli club
・ElgaeRX FUTABA S-FHSS 8Ch receiver⇒DEVO7E Deviation NG、FUTABA T14SG OK。
・SPEKTRUM DSM2 satellite receiver⇒DEVO7E Deviation OK。
・SP RACING F3 EVO Brush Flight Control Board
09 Sep 2016 20:11 #53702 by victzh
OK, I will try to tune it with SF700S I have.
02 Oct 2016 00:26 #54489 by micro heli club
Again I want to use the S-FHSS (S-BUS) receiver. Is there a way?
Time to create page: 0.370 seconds
