Bugs 3 mini
- Kentuckian
- Home is Bullitt County, Ky
01 Sep 2019 16:44 #75071
by Kentuckian
Live in FailSafe mode
Replied by Kentuckian on topic Bugs 3 mini
Which FW .dfu are you using? I hope you'll post up your finished .ini when it's fully tweaked!
- davdrone1
- davdrone1
01 Sep 2019 22:10 #75072
by davdrone1
Time flies like a banana
Replied by davdrone1 on topic Bugs 3 mini
Still using the latest .dfu that came out on 6 Jun 2019. Not sure yet if I need more work on either the Bugs 3 or Bugs 3 mini models.
Time and more ambitious flying will tell ...
- Kentuckian
01 Sep 2019 22:51 #75073
by Kentuckian
That be .dfu of nightly builds 2019-6-9 right?
- davdrone1
- davdrone1
07 Sep 2019 01:39 #75081
by davdrone1
Think I've got the settings pretty well right for how I use my EX2 mini. Unchanged from the model.ini I out up on the previous page.
Here's a recent flight -
- davdrone1
- davdrone1
23 Nov 2019 01:44 - 23 Nov 2019 01:54 #75469
by davdrone1
Still have the problem that with my EX2 mini that I have to step thru to get to "Bind" and press the ENT button every time I power on the Jumper and then drone.
Looking back thru the thread, I tried to go to the protocol options dialog to write down the "RX Id" value, then look up the value in the spreadsheet, so that I could edit the model.ini file [protocol_opts] section, to fill the Address=
Problem is that under the current Nightly Build (deviation-t8sg-v5.0.0-28ce50f) for my Jumper T8SG when I press "Enter" in the "Bugs3Mini" Protocol Field, the only thing displayed is Format Bugs3Mini. I don't see the screen as per Jay Drone's video, with the RX Id and Address displayed. Is this because we are supposed to no longer need to look up the RX Id?
Last edit: 23 Nov 2019 01:54 by davdrone1.
Time to create page: 0.872 seconds
- Bugs 3 mini
