Support for walkera telemetry.
22 Jul 2013 06:38 #12414
Replied by vlad_vy on topic Support for walkera telemetry.
I wiil test RPM sensor when I return to home today.
22 Jul 2013 08:26 #12417
Replied by FDR on topic Support for walkera telemetry.
Thanks, Vlad!
- dobosatti
22 Jul 2013 09:29 #12418
by dobosatti
Replied by dobosatti on topic Support for walkera telemetry.
Vlad_vy Thank you!
I look forward to your response.
22 Jul 2013 13:18 #12423
Devo 8s - both my RPM sensors works fine.
When I turn on the radio and bind, the RPM box at main screen is red and display zero, but if I move magnet in front of RPM sensor, box become white and display rpm value. The telemetry window has both white RPM boxes and display zero, but if I move magnet in front of RPM sensor, corresponding RPM box display rpm value.
22 Jul 2013 13:20 #12424
Is that a current build, or the official v3.0.0?
22 Jul 2013 13:25 - 22 Jul 2013 13:26 #12425
Intermediate build, after v3.0.0 but before PB newgui (9a3467b34f51).
Last edit: 22 Jul 2013 13:26 by vlad_vy.
- Hexperience
22 Jul 2013 13:33 #12426
by Hexperience
Replied by Hexperience on topic Support for walkera telemetry.
Mind posting a picture of your installs? I have two of my heli's with the telemetry modules and figure for about $8 I might as well add rpm too.
- RandMental
22 Jul 2013 13:42 #12428
by RandMental
Replied by RandMental on topic Support for walkera telemetry.
I also would not mind seeing how you did it, bought the Walkera telemetry module months back but never installed it on the V450
22 Jul 2013 13:50 #12429
Devo 12s, almost latest build (e5d75984334d), RPM sensor works fine.
Sorry, I can't help you with install example, right now my telemetry module works stand-alone.
- RandMental
25 Jul 2013 20:48 - 25 Jul 2013 20:49 #12492
by RandMental
Replied by RandMental on topic Support for Walkera Telemetry Module CTL01-D
I have tested the Walkera WK-CTLO1-D telemetry unit on both the Original Dev08s Firmware and the latest Deviation source build from PB's repository for the Devo8s using all the available sensors, including GPS.
The good news:
From this result it is clear the Deviation implementation of telemetry protocol and interpretation is correct (GPS included).
The BAD news:
The telemetry parameters on the Deviation Telemetry Monitor page do not all update continuously, given the impression some of them don't work:
(It could be that RPM1 and RPM2 also update when you go into the page, however I don't have enough hands to do the check.)
I'll file a bug report on Bitbucket for this.
The good news:
- All the Telemetry information arrives at the Devo std firmware
- All the same Telemetry information arrive at the Deviation firmware
- Any of the Telemetry parameters can be shown in boxes on the main page and it updates correctly as the parameter changes
The BAD news:
- RPM1 and RPM2 always shows zero, however when mapped to a Main Page box both work and update continuously
- Temp1, Temp2, V2, V3 and the GPS information does not update, but update if you exit the Telemetry Monitor page and go back in. When mapped to a Main Page box they all work and update continuously
Last edit: 25 Jul 2013 20:49 by RandMental.
26 Jul 2013 08:21 - 26 Jul 2013 09:16 #12507
Vlad! Did you configure the RPM values to be shown in a main page box when you tried them?
If yes, could you confirm RandMental's findings, that they are not updated on the telemetry monitor page, if they are not in a main page box too...
bitbucket.org/PhracturedBlue/deviation/i...monitor-page-not-all
Last edit: 26 Jul 2013 09:16 by FDR.
26 Jul 2013 09:15 #12508
I will check this again (with all sensors). In my case RPM and V1 values updated at Telemetry Monitor page, but I always opened this page after Tx power on and auto-bind with telemetry module.
- RandMental
26 Jul 2013 10:21 - 26 Jul 2013 10:25 #12514
by RandMental
Hi FDR,
just to clarify - my tests showed that all telemetry parameters are shown correctly when mapped to a box on the main page - I have mapped then one for one, and then each one updated as the telemetry value changed. This to me means the reception and updating of the Telemetry values are correct.
I have not yet had a look at the code, but it looks to me as a Telemetry Monitor page refresh issue, and not a telemetry issue.
As indicated earlier V1 and V3 updated and refreshed on the Telemetry page as I changed them, the other parameter fields stayed the same unless I exited the page and go back to it. Then all the fields updated to their latest values, but becomes static after that again.
FDR wrote: Vlad! Could you confirm RandMental's findings, that they are not updated on the telemetry monitor page, if they are not in a main page box too.
Hi FDR,
Last edit: 26 Jul 2013 10:25 by RandMental.
- RandMental
26 Jul 2013 10:34 - 26 Jul 2013 10:37 #12515
by RandMental
My test also involved the (normal) binding process:
TX on, Devo Protocol, 8 Channels; Cancel auto bind, go to bind/re-init page
Telemetry model on, wait for its LED to start flashing
Click the re-init/bind button on the TX (I did not used a fixed ID)
Telemetry module LED becomes solid red
Goes to the TX's Telemetry Monitor page
V1 and V3 starts updating after a few seconds
Other parameters stays on the value when the page was opened.
Hopes this help to duplicate the results I get or help my if I have the process wrong. Using the same bind process with the original Devo Firmware, all the telemetry parameters update, I am thus confident it is not a test process or bind issue.
(And when I go to the TX main page, the non responding parameters mapped to boxes on the main page, do show the updated values as they change)
vlad_vy wrote: I will check this again (with all sensors). In my case RPM and V1 values updated at Telemetry Monitor page, but I always opened this page after Tx power on and auto-bind with telemetry module.
Last edit: 26 Jul 2013 10:37 by RandMental.
26 Jul 2013 10:35 - 26 Jul 2013 10:39 #12516
I see, but a friend of mine has a similar issue: he's RPM values do not update at all, so I asked Vlad to try that, and he confirmed the RPM values are updated, which contradicts your findings. That's why I asked him about if he looked at the main page or at the telemetry monitor...
EDIT: However my friend has looked at the main page and the telemetry monitor too, but neither has been updated, so he might have some other issue, like a hardware one...
Last edit: 26 Jul 2013 10:39 by FDR.
- RandMental
26 Jul 2013 10:44 - 26 Jul 2013 10:48 #12517
by RandMental
No problem at all, I appreciate that you and Vlad are also testing. My additional posts are purely to make sure you guys understand how I tested and the results I get.
Edit:
Also originally thought nothing works, that's why I went back to the other Devo8s running the Devention firmware. That proved all inputs were working, so I started the Deviation test understand why only some fields are updating.
Edit:
Last edit: 26 Jul 2013 10:48 by RandMental.
26 Jul 2013 10:52 #12518
BTW is the RPM sensor unipolar, i.e. does it matter which magnetic pole is directed to it?
26 Jul 2013 10:53 #12519
When I testing the telemetry last time, RPM and V1 values were working at both places - Main page boxes and Telemetry Monitor page. I will test this again with all sensors and all possible bindig variants.
26 Jul 2013 10:55 - 26 Jul 2013 10:55 #12520
Only one side is active, more dark side of magnet to sensor.
FDR wrote: BTW is the RPM sensor unipolar, i.e. does it matter which magnetic pole is directed to it?
Last edit: 26 Jul 2013 10:55 by vlad_vy.
26 Jul 2013 10:59 #12521
Thanks, that might be the issue than...
Time to create page: 1.682 seconds
- Support for walkera telemetry.
