failsafe landing gear DEVO 12E
- cedric
12 Sep 2014 07:00 - 12 Sep 2014 07:16 #25629
by cedric
failsafe landing gear DEVO 12E was created by cedric
hello, I just installed a retractable landing gear HML650 on my Tarot FY690S and I can not find how to get values for failsafe in case of loss of the radio every single landing gear opens. Can you give me the process, I work as an expert on Radio mode,connected in GEAR slot Rx, GEAR switch for command
I change the values of safety in the root of GEAR but I think not.
thank you in advance
Last edit: 12 Sep 2014 07:16 by cedric.
- mikemacwillie
13 Sep 2014 02:03 #25637
by mikemacwillie
Replied by mikemacwillie on topic failsafe landing gear DEVO 12E
Which RX are you using?
- cedric
13 Sep 2014 14:17 #25641
by cedric
Replied by cedric on topic failsafe landing gear DEVO 12E
i'm use RX devo 1002
- cedric
16 Sep 2014 06:13 #25690
by cedric
up, no responce?
- mikemacwillie
16 Sep 2014 20:09 #25695
by mikemacwillie
On the same page as you're seeing the safety value (Channel configuration of the gear channel, under model config, then mixer), there is a fail-safe value which you can set.
- cedric
17 Sep 2014 04:49 #25698
by cedric
ok i go test in the day and reply expérience
17 Sep 2014 07:00 #25699
Replied by FDR on topic failsafe landing gear DEVO 12E
But you use the stock fw on your 12E, don't you?
AFAIK it isn't supported by deviation...
- cedric
17 Sep 2014 10:44 #25700
by cedric
i use 4.0.1
17 Sep 2014 18:03 #25703
On a DEVO 12E?
How do you do that? The 12E is not supported by deviation, is it?
- cedric
17 Sep 2014 19:37 #25705
by cedric
no i in F12, my 12E receives tomorrow
17 Sep 2014 20:32 #25706
Replied by hexfet on topic failsafe landing gear DEVO 12E
Does the RX1002 have a failsafe feature? (I thought it does not)
- cedric
17 Sep 2014 20:35 #25707
by cedric
I know that's why I ask. I saw a video for the retractable landing gear that had one but I think it was on fubata.
18 Sep 2014 15:33 #25720
AFAIK all DEVO receivers have the fail-safe feature...
hexfet wrote: Does the RX1002 have a failsafe feature? (I thought it does not)
- mikemacwillie
18 Sep 2014 15:34 #25721
by mikemacwillie
That's my understanding as well, but I only have experience with the RX1202.
20 Sep 2014 02:04 #25743
Just received my first servos and tried it out. The RX1002 does indeed support failsafe. Not mentioned in the Walkera documentation...
- cedric
20 Sep 2014 08:07 - 20 Sep 2014 14:39 #25744
by cedric
Grrrr.... dommage
i receved my F12E whit rx1202 white,failsafe it's ok in this Rx?
Last edit: 20 Sep 2014 14:39 by cedric.
- mikemacwillie
21 Sep 2014 15:12 #25754
by mikemacwillie
Yep, should be the same as the black one.
Time to create page: 0.597 seconds
Stock Firmware Help
- failsafe landing gear DEVO 12E
