DEVO F12 FIRMWARE
- romieux
02 Apr 2015 20:56 #30709
by romieux
DEVO F12 FIRMWARE was created by romieux
Hi I am looking for devo F12 firmware with walkera origin config (dfu, lib...).
Does someone can help me because no answers by walkera and others dealers.
I have update my devo F12 with V4..deviation F12E without saving origin firmware and now i have only white screen .... and anyone backup..
thanks
thanks
- victzh
02 Apr 2015 21:16 #30710
by victzh
Replied by victzh on topic DEVO F12 FIRMWARE
Did you check this:
www.iuasinc.com/firmware/
I can't guarantee anything and I am not affiliated with it in any kind, that's what you get for Google request "devo f12 original firmware".
02 Apr 2015 21:27 - 02 Apr 2015 21:28 #30711
Replied by PhracturedBlue on topic DEVO F12 FIRMWARE
that is only the devo f12e firmware, I do't think it will work in a devo f12. You could try it, it can't be any worse than where you are now. You could also try the deviation 'devo12' firmware which also may work (though no video). Or maybe that is what you tried. There is no Deviation for the Devo F12 OR Devo F12E. Only for the devo 12/12s and an experimental 12e
Walkera is really idiotic with their naming. Seriously:
devo12 and devo12s = same
devo12e,devo f12, devof12e all completely different
I haven't seen the 'devo f12' firmware anywhere. I was serious when I recommended contacting Walkera. they have provided firmware files to users in the past who tried to install the wrong one.
Last edit: 02 Apr 2015 21:28 by PhracturedBlue.
03 Apr 2015 04:15 #30730
Replied by vlad_vy on topic DEVO F12 FIRMWARE
I think Devo F12 and Devo F12E firmwares are incompatible, they use completely different display processing. Devo F12 has graphic display with video, Devo F12E has text display with video.
- romieux
03 Apr 2015 12:09 #30743
by romieux
Replied by romieux on topic DEVO F12 FIRMWARE
hi, it's true i never found f12 firmware and i have already trye all the others firmware F12E 12S ...nothing good.
I have been on Walkers.com but i don't find the mail address to ask them the good firmware.
Anyone know the email ,
03 Apr 2015 12:55 #30745
Try this:
I found it here:
www.walkera.com/en/article.php?id=92
I found it here:
- romieux
03 Apr 2015 15:17 #30750
by romieux
thanks PhractureBlue, i send them my request.
- romieux
19 Apr 2015 15:22 #31362
by romieux
Hi, It is still the same problem, walkera told me to follow the manual instructions to restore F12 devo . The manual only restores the model aircraft ...
Someone could it copy its devo F12 programs and send them to me? I think this is the only way to make it work . I sent several mail to walkera and no one answers . I frankly wonder if their customer service is serious.
19 Apr 2015 15:42 #31364
It's impossible to upload firmware from Walkera Tx.
19 Apr 2015 16:04 #31366
you might ask over on RCGroups. I'm sure some folks have gotten firmware from Walkera after flashing the wrong one (it is how we got the devo7e originally). If you could get the contact of an engineer in the company rather than customer support, you would get a lot farther. As vlad said, there is no (reasonable) way to extract the firmware from the transmitter. You really need to get it from Walkera. Even if I could develop Deviation for the F12, we don't have any support for FPV in Deviation, so the best case would likely be that it turns into an expensive Devo12S. I also can't do much of anything without access to one.
19 Apr 2015 16:12 - 19 Apr 2015 16:15 #31368
You can try ask Gektor from
walkera-fans.de
He can be also found at RCGroups.
Last edit: 19 Apr 2015 16:15 by vlad_vy.
- Wesley_1978
08 Dec 2015 22:03 #40720
by Wesley_1978
Replied by Wesley_1978 on topic DEVO F12 FIRMWARE
Did you get it back running? I got the same problem :-/
- Shadowfox
14 Feb 2016 11:57 - 14 Feb 2016 12:03 #43109
by Shadowfox
Replied by Shadowfox on topic DEVO F12 FIRMWARE
My Stock F12 is showing on the about screen:
Hardware: Ver. 1.0
Software: Ver. 1.3A
Library Ver: 0.3
If any of you guys knows a way to copy this stock firmware, I will upload it here..
Cannot wait to upgrade mine, but all the different confusing numbers like F12/12S/F12E
and of course your bad experiences are making me scared!
Hopefully something will come for the F12
Hardware: Ver. 1.0
Software: Ver. 1.3A
Library Ver: 0.3
Last edit: 14 Feb 2016 12:03 by Shadowfox. Reason: Bad English
14 Feb 2016 13:57 #43112
Replied by FDR on topic DEVO F12 FIRMWARE
You can't download the firmware from the transmitter, because it is read protected.
If you have the DFU files, I would like to upload them to this site, so please PM me, and I will give you an FTP login...
15 Mar 2016 20:37 #44620
Thanks to Shadowfox (and Walkera), the original F12 firmware is available on our Google drive:
drive.google.com/folderview?id=0B6SupsT8...jTkZvTFpPU1MxTDRGTnc
...so now there is a possibility to revert back after trying deviation test buils, if somebody would make one...
- nic05
23 Mar 2016 05:08 #45030
by nic05
Replied by nic05 on topic DEVO F12 FIRMWARE
Everything worked , thx ! wait 1,5 years
love my f12 .
true shortly before even rebuild !
lg
love my f12 .
lg
- diy
- aerocarv
05 Feb 2021 22:58 #77206
by aerocarv
Replied by aerocarv on topic DEVO F12 FIRMWARE
Gotta ask:
Will there be deviation firmware for DEVO F12???
I just bought one for just this reason.
I have a F12E, fine transmitter, but useless video monitor, except on a dark cloudy day.
F12 is vastly better.
Please advise. Perhaps a Nightly Build?
Thanks.
Ed Sweeney
Thanks.
Ed Sweeney
- aerocarv
05 Jan 2022 13:47 #77641
by aerocarv
Thanks for the email and the two .dfu files. How are they used? I find no way to open the F12's internal disk drive. With other DEVO's you hold the ENT button while turning on the transmitter. Does not work with the F12. Do you know if these .dfu files will allow loading Deviationx to the transmitter?
- Amandrake
26 Jan 2022 06:08 - 26 Jan 2022 06:12 #77759
by Amandrake
Replied by Amandrake on topic DEVO F12 FIRMWARE
Hello I bought a beautiful devo f12, believing that on the market there was the possibility to install deviation tx, I was able to appreciate your work on the deve 8s and the deve f12e, PLEASE, DOES SOMEONE KNOWS IF THE DEVO F12 is COMPATIBLE WITH DEVIATION FIRMWARE FOR 12S? I LOVE THIS RADIO, I NEED HELP PLEASE
Last edit: 26 Jan 2022 06:12 by Amandrake.
Time to create page: 1.787 seconds
Stock Firmware Help
- DEVO F12 FIRMWARE
