Upgrade without USB connection T8SG V2+ ?
- popad
01 Feb 2019 12:57 #72659
by popad
Upgrade without USB connection T8SG V2+ ? was created by popad
If usb connection not working it is possible to upgrade software on T8SG V2 Plus ?
My T8SG V2 Plus work well like radio station. I think for future upgrade when will be necessary.
I think that firmware in some way was loaded in my station on production time, but nobody check if USB connection work
I'm right ? May be not. To change mother board the total cost is 50$, and I do not have confidence that this will solve this issues.
Other suggestions ?
Other suggestions ?
01 Feb 2019 15:58 #72661
Replied by hexfet on topic Upgrade without USB connection T8SG V2+ ?
Perhaps the proper USB driver is not present. Are you on Windows 10? Is there any reaction on the PC when the radio is plugged in? Does the T8SG appear in the device manager list? (possibly under universal serial bus controllers, with a yellow triangle on the icon)
Can't really upgrade without being able to access the USB filesystem. Sometimes the filesystem needs to be updated along with the upgrade.
- popad
01 Feb 2019 18:32 - 01 Feb 2019 18:33 #72662
by popad
Replied by popad on topic Upgrade without USB connection T8SG V2+ ?
Thank you for answer. I have tried on Windows XP and 7, Ubuntu 16.04 and now trying hard on Ubunntu 18.04.
Sure I have installed drivers. On Windows 7 at a moment I ave received defective USB device error. Was the best
I try to use on Ubuntu 18.04, DeviatioUpload-0.9.0.jar. No success, because program run, but when start T8SG V2+ with ESC and Power buttons, program do not see any DFU device. I try to see what to need to setup in /etc/udev/rules for that.
A lot of time spent for that ...
Last edit: 01 Feb 2019 18:33 by popad.
01 Feb 2019 23:10 #72665
It does sound like a problem with the connection. The USB interface doesn't have a lot of circuitry to got bad. If you haven't already check the connector pins inside and out, and the soldering and wiring. Check the pins of the MCU are soldered nicely. Use a known-good USB cable. That's about all the can go wrong except a problem with the MCU itself.
- popad
03 Feb 2019 18:25 #72693
by popad
I have no ideea what pins from MCU are for USB, to check trackts from these to USB connector ... Any suggestions ?
I check 2 trackts from USB connector until matherboard connector ...
03 Feb 2019 21:44 #72696
On the V2+ the USB +/- signal pins are on the bottom of the mcu (with tx facing away from you, back cover removed, battery down), the fourth and fifth pins from the bottom right corner. (Sorry can't get pic right now). These should be connected directly to two of the USB connector pins.
- popad
04 Feb 2019 07:55 #72706
by popad
04 Feb 2019 08:17 - 04 Feb 2019 08:26 #72708
Replied by vlad_vy on topic Upgrade without USB connection T8SG V2+ ?
The MCU pin 29 enable USB. Probably resistor (180Ohm ???) to the left from "????" box is connected to this box. I think it can be damaged transistor or no connection from transistor to "????" box. With USB mode enabled has to be 3.3V on resistor (180Ohm ???).
Last edit: 04 Feb 2019 08:26 by vlad_vy.
- popad
04 Feb 2019 11:25 - 04 Feb 2019 13:44 #72711
by popad
Last edit: 04 Feb 2019 13:44 by popad.
- popad
10 May 2019 06:24 #74265
by popad
Is possible to use FTDI connected to A9 and A10 from STM32 ? I bought an mini development board with STM32F103RCT6 to make some experiments.
For moment I go with T12 Plus. T8SG Plus become my experimental station
10 May 2019 12:30 #74270
Yes it's possible. Info in second paragraph of
this post
- popad
10 May 2019 12:41 - 10 May 2019 12:49 #74271
by popad
Many thanks. I will try this. May be I will save my T8SG+
Not very clear for me what bootloader I must flash. Can you tell me, please. Thanks.
hexfet wrote: Yes it's possible. Info in second paragraph of this post .
Last edit: 10 May 2019 12:49 by popad.
11 May 2019 00:42 #74277
Use devo7ebootloader_256.bin. Available through the Downloads link in the left column.
- I.A.G.A
20 Aug 2019 03:21 - 20 Aug 2019 03:25 #74945
by I.A.G.A
Replied by I.A.G.A on topic Upgrade without USB connection T8SG V2+ ?
Hello, I think I lost all of the protocols and subprotocols on my brandnew Jumper T8sgPLus V2. I cann't no longer find the supported models as for the drones MJXQ and the Hubsan into the settings on the RC or by using the usb-mode using deviationtx. I want to bind my MJX Bugs 5W and my Hubsan H 502S with this brandnew RC. On my T8sgPlus the usb-connection works well and I have access to the system of the T8sgPlus V2, that's not the problem here.I've already build the external voice module but the folowing step is to setup this both models using deviationtx that's verry hehlpfull for my as a blind pilot of this drones. Many thanks in advance for any help and suggestions!
Last edit: 20 Aug 2019 03:25 by I.A.G.A.
Time to create page: 0.819 seconds
Stock Firmware Help
- Upgrade without USB connection T8SG V2+ ?
