model_config:hisky_fbl-70_on_devo_10_ht8
Hisky FBL-70 On Devo 10 / HT8
This is my Hisky FBL-70 fixed pitch configuration for the Devo 10 w/HT8 module. I started with the 4ch w/Dual-Rates template but made a lot of changes.
This flys well for me but as always - test all functions before attempting to fly and use at your own risk.
Channels are:
1. ELE (rev)
2. AIL (rev)
3. THR (rev)
4. RUD (nor)
Throttle hold is active on RUD DR0 - I find it easier to hit quickly that way. Toggle icons indicate TH and D/R status.
This setup uses the FMODE switch as follows, based on my current skill level:
FMODE0 - easy to fly with more responsive regular blades
FMODE1 - easy to fly with bulleted blades
FMODE2 - full rates & no expo, also good for heavier battery
Of course even 100% rates are still much easier to fly than the Hisky FBL-80cp.
Comments and suggestions are totally welcome. I am learning as I go. Easy to make changes to suit your skills. Also check out my FBL-80 config soon.
regards . . . g
edit - I'm not sure why the file was renamed so strangely
haacb3c2
model_config/hisky_fbl-70_on_devo_10_ht8.txt (9826 views) · Last modified: 2013/07/29 20:36 by gordonzo
