model_config:nine_eagles_solo_pro_125_-_standard_settings
Nine Eagles Solo Pro 125 - Standard Settings
Nine Eagles Solo Pro 125 (125A)
  • Low dual rates and positive expo to tame the heli down * Throttle hold on the RUDD D/R switch * 7 Point Throttle and Pitch Curves * TX Power=100mW * Channels=6 * Protocol=J6Pro * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Model 46 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gyro Gain - These are the values I used then converted them to the deviation values.
Gear Switch
Pos 0: 38%
Pos 1: 75%
Throttle Curve
Normal: Custom Curve
ST-1: 100% Flat Across
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Hover at about half throttle.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP LIN
1- AILE D/R = 100% EXP LIN
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model46
model_config/nine_eagles_solo_pro_125_-_standard_settings.txt (39011 views) · Last modified: 2014/02/04 15:29 by Tom Z
