model_config:t-rex_450_fbl-rx701_devo-zyx-s_fbl_module
T-rex 450 FBL-RX701 Devo-ZYX-S FBL module...
T rex 450 FBL(Tarot module) 3D flights setup,Gov. store mode on (YGE esc)
Swashplate : none (ccpm in the FBL module)
Elev.+Ail. Cyclic Dual Rate/EXPO : ELEV D/R switch(-10%,+15% Expo)
Rudder Dual rate/EXPO : AIL D/R switch (“ ” “ ” “)
Timer : GEAR switch
Throttle HOLD : RUDD D/R switch
Normal Flight : FM0(70% thrott.)
Stunt 1 : FM1(80% thrott. straight line)
Stunt 2 : FM2(85% ” “ ” “ ” “)
Rudder Gyro gain : Prog.mix switch 0 : 75%(HL mode) , Prog.mix 1 :65%(HL mode) , Prog.mix 2 : 40%(normal mode)
model1
model_config/t-rex_450_fbl-rx701_devo-zyx-s_fbl_module.txt (12555 views) · Last modified: 2012/10/01 11:23 by Bubu38
