User Tools
Site Tools
model_config:tarot_align_450_dfc_w_walkera_2702v_3-axis
Tarot/Align 450 DFC w/ Walkera 2702v 3-axis
Tarot 450 dfc:
rx2702v-d 3-axis receiver.
CC Ice 50 governed to 3100rpm with 9.3:1 gear ratio, 3400kv motor. You will need to set up different throttle curves if you are not using a governor.
ds415m cyclic servos. savox sh-1257mg tail servo.
Ail, Ele, or Col(Pitch) might have to be inverted in the swash settings; be sure your swash is tilting in the right directions.
No expo so it could be twitchy.
Do not use this unless you are at least a bit familiar with deviation and setting up a 2702v 3-axis, I don't want anyone to get hurt.
Edit: I have re-uploaded the .ini to not include my subtrims and ccpm offesets because anyone else who uses this will have to set up different ones i'm sure.
t450
model_config/tarot_align_450_dfc_w_walkera_2702v_3-axis.txt (5412 views) · Last modified: 2012/10/03 14:46 by flint723
