model_config:walkera_cp_helicopters_-_3d_settings
Walkera CP Helicopters - 3D Settings
This model will work on the following helicopters.
  • Walkera V120D02S * Walkera V120D02S V2 * Walkera Mini CP * Walkera Super CP * Walkera Genius CP V1/V2 * Walkera V100D08
*If you are using the V120D02S, V120D02S V2, Genius CP V1 with the WK-2801 Pro compatible Receiver change Protocol=DEVO to Protocol=WK2801.
Model 33 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 33-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 33 instead.
I have test flown this model in my Devo 10.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
  • Throttle hold on the RUDD D/R switch. * 7 Point Throttle and Pitch Curves. * TX Power=100mW * Channels=7 * Protocol=DEVO * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Throttle Curve
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
64% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 82% gyro gain.
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP +30%
0- AILE D/R = 100% EXP +30%
RUDD D/R = 100% EXP -10%
Switch Position
1- ELEV D/R = 125% EXP LIN
1- AILE D/R = 125% EXP LIN
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model33_2014-01-26
model33-2
model_config/walkera_cp_helicopters_-_3d_settings.txt (6395 views) · Last modified: 2014/01/26 07:28 by Tom Z
