model_config:walkera_master_cp_-_3d_settings
Walkera Master CP - 3D Settings
Buildem336 (Manuel) 3D settings
Here is a video of the stock Master CP flying with the settings below. He is not using the deviation firmware but I converted the settings over for the deviation firmware.
Walkera Master cp 3d flight
http://youtu.be/izTsmE6Ibyo
  • TX Power=100mW * Channels=7 * Protocol=DEVO * No Fixed ID * Throttle Hold is active on RUDD D/R switch. * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
  • Travel Adjustment: Pitch = 54% * Pitch Travel has been set so that there is no bogging of the motor. * 7 Point Throttle and Pitch Curves.
Model 9 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 9-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 9 instead.
Model 2 is for deviation firmware v3 and the Devo 8/8S/12.
Model 28 is for deviation firmware v3 and the Devo 10.
See the post below this for the Devo 6S Model.
I have test flown this model in the Devo 10 transmitter.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: -100, -33, 33, 100, 100, 100, 100
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: About -1.5* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
64% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 82% gyro gain.
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP LIN
0- AILE D/R = 100% EXP LIN
RUDD D/R = 100% EXP EXP -6%
Switch Position
1- ELEV D/R = 100% EXP LIN
1- AILE D/R = 100% EXP LIN
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Install the configuration settings file into your models folder.
Example: The file you downloaded is named model5 so change the “5? to another slot
See my video:
http://youtu.be/aXkvtbCXzsk
model9-2_2014-01-26
model2
model28
model9
model_config/walkera_master_cp_-_3d_settings.txt (6137 views) · Last modified: 2013/04/10 09:26 by Tom Z
