model_config:walkera_qr_x350_configs_for_devo_10
Walkera QR X350 Configs for Devo 10
I have finally taken the jump into Deviation with the new version 4 firmware. So far it is spectacular!
I have created a couple of model configs for my QR X350 and wanted to share them here.
QRX350-multi D/R
Rudder, Elevator, Aileron Dual Rates all individually controlled via corresponding switch. All set at 60% when switch is set to 1, both full and dual rate mode use +60 exponential.
Gear - 0 disables (-100%) throttle, 1 enables throttle
Mix (CH6) - 0 IOC disabled (100%), 1&2 IOC enabled (-100%) not tested may be backwards FMODE (CH5) - 0 Manual Mode (-100%), 1 Position Hold (0%), 2 Return to Home (100%) Timer count down current set to 8 minutes and enabled when throttle is > -90%. Timer count up enabled when throttle is > -90%. Main screen customized to indicate status of D/R switches on top left; Gear, Mix and FMODE are reverse video as they are custom features. QRX350-single D/R Rudder, Elevator, Aileron Dual Rates all controlled via Rudder D/R switch. All set at 60% when switch is set to 1, both full and dual rate mode use +60 exponential. Gear - 0 disables (-100%) throttle, 1 enables throttle Mix (CH6) - 0 IOC disabled (100%), 1&2 IOC enabled (-100%) not tested may be backwards
Main screen customized to indicate status of Rudder D/R switch on top left; Gear, Mix and FMODE are reverse video as they are custom features.
qrx350-multidr
qrx350-singledr
model_config/walkera_qr_x350_configs_for_devo_10.txt (76066 views) · Last modified: 2014/01/02 10:38 by DrDigital
