voiceoutput
voiceoutput [2018/05/03 08:48]
Moeder Add hardware info for T8SG V2
voiceoutput [2018/05/12 09:27] (current)
Moeder [Setting up the emulator for voice alerts]
Line 107: Line 107:
 == Voice Files: == == Voice Files: ==
-Deviation software nightly builds do not include the voice files, and the user must also download a basic set of voice alerts. ​ The files are currently available in the [[http://​deviationtx/​downloads-new|Deviationtx.com Downloads]] folder under [[https://​www.deviationtx.com/​downloads-new/​category/​705-moeder-voice-alerts|Test Builds/​[Moeder]voice_alerts]] and are available in English, French and German. ​ An expanded set of English voice alerts is also available.  ​Each zip file includes the required MP3 Folder and a voice.ini file catalog.+Deviation software nightly builds do include the voice features since April 2017, but the user must also download a set of voice alerts. The files are currently available in the [[http://​deviationtx/​downloads-new|Deviationtx.com Downloads]] folder under [[https://​www.deviationtx.com/​downloads-new/​category/​1010-moeder-voice-packs|Test Builds/​[Moeder]voice_packs]] and are available in English, French and German. Each zip file includes the required MP3 Folder and a voice.ini file catalog.
-You can also use the [[https://​moeder.pythonanywhere.com/​voicepacker/​default/​index|Deviation Voicepacker]] service to create your own custom voice sets. This service will continue to evolve ​in the next weeks.+You can also use the [[https://​moeder.pythonanywhere.com/​voicepacker/​default/​index|Deviation Voicepacker]] service to create your own custom voice sets. This service will continue to evolve.
 The files for the DFPlayer are saved using MP3 format and are contained in the //\MP3// folder on the MicroSD card.  The MicroSD must be set up with the //\MP3// folder and all the voice alert files must be in that folder. ​ No other files or folders need to be on the card, so the card can be a small as 64MB (the actual disk storage for the largest file set is under 2MB). The files for the DFPlayer are saved using MP3 format and are contained in the //\MP3// folder on the MicroSD card.  The MicroSD must be set up with the //\MP3// folder and all the voice alert files must be in that folder. ​ No other files or folders need to be on the card, so the card can be a small as 64MB (the actual disk storage for the largest file set is under 2MB).
Line 149: Line 149:
 ==== Setting up the emulator for voice alerts ==== ==== Setting up the emulator for voice alerts ====
-Download and unzip the emulator package for your transmitter.  Then make these changes: +Download and unzip the emulator package for your transmitter.
-  - Be sure that the file //​mp3123.exe//​ is in main folder with emulator exe package; it is now included in the nightly emulator builds. +  - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe.  The //\mp3// folder is included in the voice alerts zip file from [[https://​www.deviationtx.com/​downloads-new/​category/​1010-moeder-voice-packs|Test Builds/​[Moeder]voice_packs]] or in the voice packs created by [[https://​moeder.pythonanywhere.com/​voicepacker/​default/​index|Deviation Voicepacker]].
-  - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe.  The //\mp3// folder is included in the voice alerts zip file from [[https://​www.deviationtx.com/​downloads-new/​category/​705-moeder-voice-alerts|Test Builds/​[Moeder]voice_alerts]] or in the voice packs created by [[https://​moeder.pythonanywhere.com/​voicepacker/​default/​index|Deviation Voicepacker]].+
   - Update the file system as you would update the TX file system:   - Update the file system as you would update the TX file system:
   * Make appropriate changes to the //​hardware.ini// ​   * Make appropriate changes to the //​hardware.ini// ​
   * Copy the //​voice.ini//​ to the //\media// folder   * Copy the //​voice.ini//​ to the //\media// folder
   * Edit each //​model.ini//​ to enable sounds or use the voice configuration menu (except devo7e, see above).   * Edit each //​model.ini//​ to enable sounds or use the voice configuration menu (except devo7e, see above).
voiceoutput.1525362500.txt.gz (153992 views) · Last modified: 2018/05/03 08:48 by Moeder
