voiceoutput
| Both sides previous revision Previous revision | |||
| Line 150: | Line 150: | ||
| Download and unzip the emulator package for your transmitter. | Download and unzip the emulator package for your transmitter. | ||
| - | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_alerts]] or in the voice packs created by [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]]. | + | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_packs]] or in the voice packs created by [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]]. |
| - Update the file system as you would update the TX file system: | - Update the file system as you would update the TX file system: | ||
| * Make appropriate changes to the //hardware.ini// | * Make appropriate changes to the //hardware.ini// | ||
| * Copy the //voice.ini// to the //\media// folder | * Copy the //voice.ini// to the //\media// folder | ||
| * Edit each //model.ini// to enable sounds or use the voice configuration menu (except devo7e, see above). | * Edit each //model.ini// to enable sounds or use the voice configuration menu (except devo7e, see above). | ||
voiceoutput.1526142405.txt.gz (154268 views) ยท Last modified: 2018/05/12 09:26 by Moeder
