New WLToys Protocol V977
- bazsound
28 Jul 2016 20:53 #52246
by bazsound
Replied by bazsound on topic New WLToys Protocol V977
Theres a mistake in your model file, this really confused me as a new devo user wondering why throttle hold didnt work .
Did you check it before posting? your Destination is set to ch5 instead of 6
wukong wrote: Continuing the post:
Transmitter Configuration: (based mainly off 8ch ini by FlipRide and added ch9-11 from Babay)
I'm using the following switch configuration on my Devo 10:
Throttle Hold: Rudder DR1
6G Mode: F.MOD0
3D Mode: F.MOD1
Idle up: F.MOD2
Dual Rates on Heli (Ch 5 in protocol): AIL DR1
Dual Rates on Devo 10:
Slow: MIX0
Mid: MIX1
Fast: MIX2
Here's how i set up my model ini:
Standard stuff for a start:name=V977 mixermode=Advanced [radio] protocol=KN num_channels=11 fixed_id=134562 tx_power=150mW
Throttle/Pitch on Channel 1: Just simple linear curve.[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
Aileron on Channel 2: Expo DR curve with the following settings: (if you are entering this into Devo10 by hand, the GUI has high rates as a default, so the label is opposite of mine in case you are confused.)
Slow Rate Default (no trigger or MIX0) Scale to 60% Symmetric, Expo 60 Curve Mid Rate MIX1 Scale to 85% Symmetric, Expo 60 Curve Fast Rate MIX2 Scale to 125% Expo 0 curve/ 1 to 1 curve [channel2] template=expo_dr [mixer] src=AIL dest=Ch2 scalar=60 curvetype=expo points=60,60 [mixer] src=AIL dest=Ch2 switch=MIX1 scalar=85 curvetype=expo points=60,60 [mixer] src=AIL dest=Ch2 switch=MIX2 scalar=125 curvetype=expo points=0,0
Elevator on Channel 3: Pretty much the same as Aileron[channel3] template=expo_dr [mixer] src=ELE dest=Ch3 scalar=60 curvetype=expo points=60,60 [mixer] src=ELE dest=Ch3 switch=MIX1 scalar=95 curvetype=expo points=60,60 [mixer] src=ELE dest=Ch3 switch=MIX2 scalar=125 curvetype=expo points=0,0
Rudder on Ch4: Similar to Throttle[channel4] template=simple [mixer] src=RUD dest=Ch4
Dual Rates on Heli on Ch5: Min/Max curve for ON/OFF. AIL DR0= Normal Rates, AIL DR1 = Double Rates[channel5] template=simple [mixer] src=AIL DR1 dest=Ch5 curvetype=min/max points=0
Throttle Hold on Ch6: Similar to Ch5. RUD DR0 = Hold OFF, RUD DR1 = Hold ON[channel6] template=simple [mixer] src=RUD DR1 dest=Ch5 curvetype=min/max points=0
Idle Up on Ch7: Similar to Ch5/6. FMODE2 to activate, FMODE 1 and 0 will deactivate. (Idle up not available in FMODE0/ 6G mode anyway)[channel7] template=simple [mixer] src=FMODE2 dest=Ch7 curvetype=min/max points=0
3D/6G flight mode on Ch8. Similar to ch5-7. FMOD0 to activate 6G mode, FMODE1 for 3D Mode[channel8] template=simple [mixer] src=FMODE0 dest=Ch8 scalar=-100 curvetype=min/max points=0
Trim channels 9-11: Haven't adjusted them yet, didn't see the need so far.
[channel9] template=simple [channel10] template=simple [channel11] template=simple
Virtual Channel 1 for Timer 1. I like to set up one countdown timer which runs whenever the rotor is spinning, and stops when the rotor stops.
I used complex template with replace MUX, so that while Idle up is off, it counts whenever throttle is > -100%, and when Idle up is on, it counts regardless of throttle position.[virtchan1] template=complex [mixer] src=Ch1 dest=Virt1 [mixer] src=AIL dest=Virt1 switch=FMODE2 usetrim=0 curvetype=fixed
ch 9-11 trims:[trim1] src=Ch9 pos=TRIMLV+ neg=TRIMLV- step=10 [trim2] src=Ch11 pos=TRIMRV+ neg=TRIMRV- step=10 [trim4] src=Ch10 pos=TRIMRH+ neg=TRIMRH- step=10
Timer 1: See Virt1. Gear1 will reset the timer.[timer1] type=countdown src=Virt1 resetsrc=GEAR1 time=300
Time to create page: 0.112 seconds
- New WLToys Protocol V977
