New WLToys Protocol V977
- victzh
11 May 2014 06:08 #23132
by victzh
Replied by victzh on topic New WLToys Protocol V977
The code for KN protocol is accepted in the main Deviation repository. It was a true collaborative work, I just implemented it, but many people participated. Thanks to Ansheng I had early SPI traces which allowed me to resolve ambiguities in the documents. The documents were published in Chinese by KN itself, and generously translated by dc59. KN published them because of persuasion from James Chen of HiSky. I was able to verify how it all works together and tune it thanks to generous donation of V977 from Banggood facilitated by RCGroups' FyreSG and Banggood's Adam. Thanks for the first positive report when I still did not get my model to test, and for troubleshooting to Babay. And thanks to all brave people who tested the code blindly on their own helicopters.
- dc59
13 May 2014 00:10 #23164
by dc59
Replied by dc59 on topic New WLToys Protocol V977
Hi victzh,
You are the key man makes this protocol works!
Thanks.
Thanks.
- sfersystem
13 May 2014 06:42 - 13 May 2014 11:22 #23175
by sfersystem
Replied by sfersystem on topic New WLToys Protocol V977
Thank you for the very good work, wanna try on my new devo10 2km range, but what module should i install, i found in the forum the NRF24L01+ but is there not 2 different models ? where can i find the good one ?
This one is ok ?
or this one ?
This one is ok ?
or this one ?
Last edit: 13 May 2014 11:22 by sfersystem.
- victzh
13 May 2014 16:40 #23194
by victzh
The second one does not have Power Amplifier, so no. The first one is very close to what I have. I removed the SMA connector and soldered an antenna directly to the board. 2km is probably not realistic with any of this.
- SeByDocKy
13 May 2014 16:57 #23198
by SeByDocKy
you should take ths one :
www.banggood.com/2_4G-NRF24L01-PA-LNA-Wi...ntenna-p-922601.html
the PA is +20dBm instead of +17dBm for your first link. The maximum distance is around 700m@1mbit/s in a really ideal scenario... 300m in practice is more reasonable.
You 2km advertising is for a specific walkera RX associated with the QR350 pro
Replied by SeByDocKy on topic New WLToys Protocol V977
sfersystem wrote: Thank you for the very good work, wanna try on my new devo10 2km range, but what module should i install, i found in the forum the NRF24L01+ but is there not 2 different models ? where can i find the good one ?
This one is ok ?
or this one ?
- sfersystem
13 May 2014 20:24 - 14 May 2014 05:03 #23204
by sfersystem
Thank you SeByDocKy, and congratulations victzh and the team for this great work again.
Last edit: 14 May 2014 05:03 by sfersystem.
- ben1977
13 May 2014 20:57 - 13 May 2014 20:58 #23209
by ben1977
Replied by ben1977 on topic New WLToys Protocol V977
I own a Devo10 and I bought this module on Banggood which works very well :
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
With respect to the first two links, it has a PA and an antenna which can be ept inside the Tx. Which respect to the previous link, it has an antenna which is useful if you don't want to solder one on it I think.
By the way , I'm happy that we may be able in a close future to pilot a V977 BNF thanks to the fabulous work of all of you guys
Last edit: 13 May 2014 20:58 by ben1977.
- joeclone
13 May 2014 23:45 #23215
by joeclone
The nightly is already out for the V977 so basically we can already fly a BNF
Replied by joeclone on topic New WLToys Protocol V977
- dc59
14 May 2014 02:11 #23217
by dc59
Share the test modle file for V977:
DEVO 8/10:
Gear SW: 3G mode(0) / 6G mode(1)
AILE DR SW: DR High(0) / DR Low(1)
FMode SW: Normal(0) / Idle(1) / Normal(2)
RUDD DR SW: Normal(0) / HOLD(1)
DEVO 7E:
HOLD 0 : Normal
HOLD 1 : HOLD
FMODE 0 : Normal
FMODE 1 : Idle
Channel 5 DR default = DR High(Stable mode)
Channel 8 3/6G default = 3G mode
Is it ok for me to post ini file here or I should move it to Model Configs
thread?
DEVO 8/10:
DEVO 7E:
HOLD 0 : Normal
HOLD 1 : HOLD
FMODE 0 : Normal
FMODE 1 : Idle
thread?
- sfersystem
14 May 2014 05:04 - 14 May 2014 09:22 #23219
by sfersystem
Last edit: 14 May 2014 09:22 by sfersystem.
- joeclone
14 May 2014 16:23 - 14 May 2014 16:24 #23230
by joeclone
Yes please post your ini, thanks.
dc59 wrote: Is it ok for me to post ini file here or I should move it to Model Configs
thread?
Last edit: 14 May 2014 16:24 by joeclone.
- ben1977
23 May 2014 11:46 #23524
by ben1977
Hi, is it worth buying the Rtf version or the BNF is ok with the actual .ini file ? Thank you for your feedback
- Florida Heli
23 May 2014 23:47 #23546
by Florida Heli
Replied by Florida Heli on topic New WLToys Protocol V977
Hi, I'm brand new so pardon me if this question has been answered already. Will this control the v930? If so, what do I need to do? Thanks.
-Florida Heli-
-Florida Heli-
- kadaj
04 Jun 2014 13:02 #23899
by kadaj
Replied by kadaj on topic New WLToys Protocol V977
Good morning everyone, does anyone know if this module is compatible? or have to use those mentioned by you?
Thank you very much.
www.banggood.com/New-WLtoys-Radio-Adapte...44-V955-p-79221.html
or
www.hobbyking.com/hobbyking/store/uh_vie....asp?idproduct=39679
or
- joeclone
04 Jun 2014 14:06 #23900
by joeclone
No both are radio adapters that work off a tx ppm signal and both are for Hisky protocol only.
- kadaj
04 Jun 2014 14:33 #23901
by kadaj
Many thanks joeclone, then the only way is to bind using the correct internal card?
Thanks.
Thanks.
- victzh
04 Jun 2014 16:29 #23903
by victzh
Or combo with antenna:
Do not turn on the module without antenna connected - you can burn it.
- kadaj
04 Jun 2014 17:44 #23904
by kadaj
Thank you, but still did not understand why the module below does not work?
The protocol is not the same as the v922?
- Florida Heli
04 Jun 2014 17:53 - 04 Jun 2014 17:53 #23905
by Florida Heli
And does anyone know about the 4 ch fixed pitch v930? I'd like to use my Devo 10 instead of the toy TX that comes with it.
-Florida Heli-
kadaj wrote: The protocol is not the same as the v922?
-Florida Heli-
Last edit: 04 Jun 2014 17:53 by Florida Heli.
- victzh
04 Jun 2014 19:29 #23911
by victzh
Yes, the protocol of V977 is totalli different from V922. V922 is HiSky rebadged and use their protocol, V977 is produced by KN and use their own protocol.
I believe that V930 and V977 use the same protocol.
Time to create page: 0.978 seconds
- New WLToys Protocol V977
