adding_3_position_virtual_switch_to_devo_7e
adding_3_position_virtual_switch_to_devo_7e [2017/10/15 12:41]
MikeNH created
adding_3_position_virtual_switch_to_devo_7e [2017/10/24 19:25] (current)
MikeNH
Line 4: Line 4:
 What do we have to give up to create virtual switches? The trim switches. How much use does the throttle trim get? How much use does the elevator trim get? If you agree that these trim switches are rarely, if ever used, in the following steps, we will put them to good use as virtual 3 position switches. What do we have to give up to create virtual switches? The trim switches. How much use does the throttle trim get? How much use does the elevator trim get? If you agree that these trim switches are rarely, if ever used, in the following steps, we will put them to good use as virtual 3 position switches.
-The Deviation version ​ we are working with is devo7e-v5.0.0-d88c192+The Deviation version ​ we are working with is devo7e-v5.0.0-d88c192. However, all current Deviation versions are capable of implementing virtual switches.
 The general process is to first reassign the chosen trim's step value. (More about step value later). Then we create a virtual switch using the chosen trim switch. Finally, we assign a channel to the virtual switch. This is all done within a specific model because you may have craft that need these trim switches. The general process is to first reassign the chosen trim's step value. (More about step value later). Then we create a virtual switch using the chosen trim switch. Finally, we assign a channel to the virtual switch. This is all done within a specific model because you may have craft that need these trim switches.
Line 28: Line 28:
 The title of the switch can be changed to something more meaningful such as FMode if it is to be used for Flight Modes. In the ground control software use the normal channel configuration to assign behavior. The title of the switch can be changed to something more meaningful such as FMode if it is to be used for Flight Modes. In the ground control software use the normal channel configuration to assign behavior.
 +UPDATE:
 +I've recently added GPS to my quad so there is a need for even more flight modes. Adding a 5 position switch turns out to be very simple. In step 2 above, change ​   Trim Step = 100    to    Trim Step = 50. So now the tx output is +100, +50, 0, -50, -100.
adding_3_position_virtual_switch_to_devo_7e.1508096486.txt.gz (11555 views) · Last modified: 2017/10/15 12:41 by MikeNH
