model_config:jjrc1000_questions
JJRC1000 questions
I'm a noob with ini files.
Below is a bit of the .ini for my JJRC1000. Channel 5 makes the LEDs turn on or off. If I remove all the lines for channel 5 from my ini file (and give it no information about channel 5) then once bound the quad's default behavior is for the LEDs to slowly blink on and off. So therefore: the quad has three settings for its lights: on, off, and blink.
Question #1: I would like for the quad to blink like that when it is in flip mode (controlled by channel 6 and HOLD0). How could I do that? How can I make the lights blink on purpose? What command do I need to send to channel 5? Is it done with scalar? Can someone explain?
[code][channel5]
template=simple
[mixer]
src=FMODE1
dest=Ch5
[channel6]
template=simple
[mixer]
src=HOLD0
dest=Ch6
[/code]
model2-2
model_config/jjrc1000_questions.txt (5105 views) · Last modified: 2015/05/14 20:11 by Tryptych
