model_config:my_align_t-rex_450_rx1002_devo_10_config_file
My Align T-Rex 450 + RX1002 + Devo 10 config file
This is the config file I am using for my Airwolf, having a T-rex 450SE inside with a DEVO 10. It might not be the most professional config, but am flying this daily, so it works ;-)
Enjoy.
If you have some improvement ideas, please share B)
RX1002:
ELE: elevon servo: rear (outside on the left)
AIL: aileron servo: front, bottom.
THR: ESC
RUDD: Gyro
GEAR: no connect
AUX1: pitch servo: front, upper.
AUX2: Gyro gain
AUX3: no connect
AUX4: Gear servo (easier to reach…)
AUX5: no connect
Functions:
- 3 filght modes, curves by the T-rex manual FMOD
- “Sticky” throttle hold, RUDD D/R + Throttle lever to bottom first
- Slo mo gear for the Airfox body, GEAR
- Hover pitch adjust, ELEV D/R + AUX4
- 3 gyro sensitivity, 2 fixed Head hold, higher and lower, 3rd is live pot variable for setup, both rate + HH mode, MIX, AUX5
- 1 stop watch + 1 countdown, throttle start and AILE D/R reset
Screen:
- 4 trims
- left: stopwatch + count down
- right, from top: cyclic, throttle, gyro gain
wolf
model_config/my_align_t-rex_450_rx1002_devo_10_config_file.txt (131969 views) · Last modified: 2013/08/25 01:47 by billmester
