model_config:nine_eagles_solo_pro_125_-_beginner_settings
Nine Eagles Solo Pro 125 - Beginner Settings
Nine Eagles Solo Pro 125 (125A)
  • No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast.
Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
If you fly outside in wind use ST-1 or ST-2 which have full pitch curves which can pull the heli down in wind.
[li]Throttle Hold on the RUDD D/R switch.
Zero Degree Pitch when throttle hold is on.
This will help minimize damage in a crash as the swash and blades will be at mid stick zero degrees pitch. This will also help prevent a boom strike.[/li]
  • 7 Point Throttle and Pitch Curves * Low dual rates and positive expo to tame the heli down * Throttle hold on the RUDD D/R switch * TX Power=100mW * Channels=6 * Protocol=J6Pro * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Model 45 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gyro Gain - These are the values I used then converted them to the deviation values.
Gear Switch
Pos 0: 38%
Pos 1: 75%
Throttle Curve
Normal: Custom Curve
ST-1: 100% Flat Across
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Hover at about half throttle.
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model45_2014-02-04
model_config/nine_eagles_solo_pro_125_-_beginner_settings.txt (7135 views) · Last modified: 2014/02/04 15:28 by Tom Z
