model_config:nova_quanum_eventually_cheerson_cx-20
Nova Quanum (eventually Cheerson CX-20)
Here is a model config pour the quad “NOVA Quanum”.
It might work for the Cheerson CX-20
My Devo 7E is settled with 2 additional switches
Left Side (SWA) is a 2-position
Right side (SWB) is a 3-position
My firmware is a nightly build : devo7e-v4.01-3b6213a8
I have a RX701 in the quad
Notice the hardware.ini is set with “extra-switches = 3×2” as there is no option for a 3x+2x but I just had to use SWA1 and SWA2
For the flight modes, I set them to the exact same switches combinations as the stock TX of the RTF version (notice the SWA-SWB permutation that has no effect)
I have the 6th Flight Mode with both FMODE & ALT HOLD switches (this configuration is prioritary to any SWA-SWB combination). I made it “Land Mode” in order to have an idiot-proof :silly: configuration :
all 4 switches high ⇒ Stabilize mode (= manual fly)
all 4 switches down ⇒ Land mode
I use the right trims to drive the gimbals (replacement of the knobs on the stock TX)
I also set a proportional countdown timer linked to THROTTLE (value has to be set according to your battery)
I don't use the CH6 in the FC
hardware
model2
Enjoy your flights !
Yann
model_config/nova_quanum_eventually_cheerson_cx-20.txt (13111 views) · Last modified: 2014/08/11 11:21 by JWarrior
