model_config:blade_nano_cp_ncpx
Blade Nano CP / NCPx
Attached is a config for the blade NCPx / Blade Nano CP.
DR/Expo for ELE, AIL, RUD with corresponding switches on the TX.
Throttle hold with Gear switch.
FMODE0 gives you normal flight mode: pitch mostly positive and 5 points throttle from -100 to +100
FMODE1 gives you a 3 points V shaped throttle curve 100-80-100, pitch is -100 to +100 linear with 30% expo.
FMODE2 gives you a flat 100% throttle curve, pitch is -100 to +100 linear with 30% expo.
Can obviously be improved / tailored to your needs but it should get you started and flying the little bird in a mater of minutes.
Icon for NCPx can be found here : NCPx icon
Have Fun!
model_config/blade_nano_cp_ncpx.txt (105740 views) · Last modified: 2012/10/05 17:22 by rototophe
