model_config:blade_nano_cp_x_-_standard_settings
Blade Nano CP X - Standard Settings
UPDATE: 5/13/13
I have updated all the models which have the same name as before.
* Notice of Ch 3 being 0 not -100 has been corrected.
* DSM2 has been changed to DSMX.
  • Throttle hold on the RUDD D/R switch. * 7 Point Throttle and Pitch Curves. * TX Power=100mW * Channels=7 * Protocol=DSMX * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Model 6 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 6-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 6 instead.
Model 48 is for deviation firmware v3 and the Devo 8/8S/12.
Model 49 is for deviation firmware v3 and the Devo 10.
Throttle Curve - These are the values I used then converted them to the deviation values and 7 point curves.
Normal: 0% 40% 60% 80% 100%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model48
model49
model6-2
model6_2014-02-01
model_config/blade_nano_cp_x_-_standard_settings.txt (10502 views) · Last modified: 2013/04/16 16:21 by Tom Z
