model_config:hisky_fbl-80cp_on_devo_10_ht8
Hisky FBL-80cp On Devo 10 / HT8
This is my Hisky FBL-80cp configuration for the Devo 10 w/HT8 module. I started with the 6ch Helicopter template but made a lot of changes. Flight modes are based on my skill level. Transition between modes is smooth.
Channel Reverse:
1. ELE - Nor
2. AIL - Nor
3. THR - Rev
4. Rud - Nor
Scale Expo
FMODE0 (Easy):
ELE 60 30
AIL 50 30
THR 100 - 7Point: -100/-70/-35/0/35/70/100
RUD 100 -
COL 75 - 7Point: -30/-20/-10/0/35/70/100
FMODE1 (Sport):
ELE 75 20
AIL 65 20
RUD 100 -
COL 80 - 7Point: -100/-70/-35/0/35/70/100
FMODE2 (Stunt):
ELE 90 20
AIL 80 20
THR 100 - 7Point: 100/93/86/80/86/93/100
RUD 100 -
COL 85 - 7Point: -100/-70/-35/0/35/70/100
NOTE: In Deviationtx, 6ch heli throttle curve of -100/-70/-35/0/35/70/100 with 0 pitch at 0% equiv to 0/17/34/50/67/84/100 with 0 pitch at 50%.
Model setup / Model type: / Heli
—> SwashType: 120
—> ELE (servo): Inverted
—> AIL (servo): Normal
—> COL(servo): Normal
—> ELE Mix: 60
—> AIL Mix: 50
—> COL Mix: 60
Sticky Throttle Hold is active on RUD DR0. Toggle icons indicate TH and FMODE status.
I would appreciate any feedback on this configuration.
regards . . . g
EDIT: I have changed my settings as listed below:
Fmode1 THR 7Point 90/85/82/80/82/85/90
Fmode2 THR 7Point 100/95/90/85/90/95/100
Col Mix 55
These settings were suggested by FyreSG on Rcgroups. Control is much smoother.
hf8d9199
model_config/hisky_fbl-80cp_on_devo_10_ht8.txt (5901 views) · Last modified: 2013/08/01 16:49 by gordonzo
