model_config:walkera_cp_helicopters_-_beginner_settings
Walkera CP Helicopters - Beginner Settings
[color=#ff0000]UPDATE:[/color]
I corrected the switch icon issue that RandMental posted about below this post.
The models have been updated and the switch icon assignments are now correct
for the models that had the problem.
This model will work on the following helicopters.
  • Walkera V120D02S * Walkera V120D02S V2 * Walkera Mini CP * Walkera Super CP * Walkera Genius CP V1/V2
[li]Walkera V100D08
*If you are using the V120D02S, V120D02S V2, Genius CP V1 with the WK-2801 Pro compatible Receiver change Protocol=DEVO to Protocol=WK2801.
Model 7 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 7-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 7 instead.
Model 15 is for deviation firmware v3 and the Devo 8/8S/12.
Model 7v3 is for deviation firmware v3 and the Devo 10.
See my post here for the Devo 6S model.
http://www.deviationtx.com/forum/model-configs/1665-walkera-cp-helicopters-beginner-settings?start=20#8861
I have test flown this model using deviation firmware v2.1, v3, v4 in my Devo 10.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
  • No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast.
Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
If you fly outside in wind use ST- 1 or ST- 2 which have full pitch curves which can pull the heli down in wind.
  • Lower Pitch Travel Adjustment to make the heli more tame. * Low dual rates and positive expo to tame the heli down. * Throttle hold on the RUDD D/R switch. * 7 Point Throttle and Pitch Curves. * TX Power=100mW * Channels=7 * Protocol=DEVO * No Fixed ID * Stick Mode 2
If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Throttle Curve
Normal Mode: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
64% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 82% gyro gain.
DR/EXPO
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
Right click the “model.ini ” and select “Save Target As” or “Save Link As” depending if you are using IE or Firefox.
Example: The file you downloaded is named model5 so change the “5“ to another slot
http://youtu.be/aXkvtbCXzsk
model15
model7-2
model7
model7v3
model_config/walkera_cp_helicopters_-_beginner_settings.txt (3117 views) · Last modified: 2013/04/06 15:12 by Tom Z
